Question about Kitchen Ranges
Maytag Stove Model MER5570BCW purchased in 2001. Get F9 beep beep error code...oven shuts off...display says lock but door does not lock. Already replaced clock computer unit 3 days ago and checked door lock mechanism which is fine. Tonight it did same thing again.
  • 3 more comments
  • lmpaulsen Dec 19, 2008
    See above. Just replaced clock unit and had door lock mechanism checked three days ago by a Maytag repairman. Do I have to have a repairman here and replace the clock every three days? Gets pretty pricey. Something must be causing this to happen.
    What you said is exactly what the repairman said and he did both.
    Even though the door lock mechanism appeared to work...why would the F9 error code say "lock"...yet the door isn't locked...I pushed clean and the door locked as it was supposed to unlocked when I pressed cancel. The repairman tested it as well. Yet there must be a reason why on both the old clock unit and the new clock unit, when the F9 error code appeared, both times it also indicated "lock". Is there some circuit or wire that could be faulty and maybe shorting or something that would cause the F9 "lock" error code to appear?
  • lmpaulsen Dec 20, 2008
    Thank you, but even though the sensor says so, the door lock has never been a problem. Although the F9lock error code means is that it's is either the clock or the door. I now have the option of gambling on another new clock which would be number four in the seven year life of this stove, or get a new stove. The new stove is being delivered Dec. 23. Thanks anyway....
  • Ghibird Jan 26, 2009
    F9 error code - oven and broiler do not work. no beeping or message. clock stays out. For no reason clock comes back on (2-3 days) oven works again but broiler does not. Repairman thinks it is the clock unit. Have been waiting 4 weeks + for Maytag to send new unit for replacement, Hope, if it ever arrives that it will clear the problem.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls unplug unit from tha mains for an extended period of time to reset the "clock computer". Thereafter a couple of steps you may want to try:
  • visually inspect the door latch or "door lock mechanism";
  • visually inspect the tab on the door itself (might be bent, loose or out of position);
  • remove the access panel on the front of the oven to gain access to the locking device and see it it needs to manually release it;
  • press and hold the door latch to unlock position, without releasing the hold, press CANCEL for a few seconds.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 19, 2008
  • Louie  Role
    Louie Role Dec 19, 2008
    I had a second look at the wiring diagram. In some versions, there appears to be two (2) door switches; 1 lock switch and the other, a door activated switch. The first has black, red & tan wires while the second uses black, black & purple. The door activated switch trigger on the oven lamp same as the oven light switch. The 2 black wires from this switch are normally not connected.
    You may be interested to reference the wiring diagram.
    Genius:
  • 1,199 Answers
You may need to reset the stove unit (unplug for 15 minutes then replace plug) if this does not work the door lock sensor will need replaced!
  • 8,220 Answers
F9 Door Lock Warning Check door lock circuit or Replace Clock
  • Dan Webster
    Dan Webster Dec 20, 2008
    Check each wire that connects to the door locking mech one at a time by removing the wire and testing for a short between it and the frame.
    Sergeant:
    Champion:
  • 247 Answers
Welocome-
when it says F9 on the screen it means ther is something wrong with the Door Latch - Check door latch, switches and wiring. I would start here first.
thank for using fixya and let me know if you need any more help.
Tom
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
The ovens fail to work after the cleaning cycle - displays says "call service". Now both ovens will not operate and neither do the timers.
Maytag model MER6772BAW was displayying f9-2 and call Authorized
service after cleaning also top door was locked and feature were disabled. I was able to solve the problem by unplugin the stove and waited about ten seconds before re-conecting once up the top door unlocked cleared the f9-2 error by pressing Auto set button and number 9 for Defauts. Perhaps this can help you.
Aug 14, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Error message and alarm
These are the fault codes for your unit
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Hope this helps, Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Maytag MGR5870 Gas Kitchen Range
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
My frigdaire stove door finally opened manually from behind but
F9 code: An F9 code indicates the EOC has detected a problem with the motor door latch assembly. Check the contacts of the lock switch, wiring to the lock motor assembly, and the lock motor.
Dec 16, 2007 | Frigidaire FEF455BB Electric Kitchen Range
Kitchen Ranges Logo
529 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
