Question about Olympus FE-220 Digital Camera
Picture lock I have an fe-220 olympus I am unable to delete one picture because it has a green key symbol which I assume it is locked, I cannot figure out how to get rid of this.
  • jcavagnaro Jan 18, 2009
    I have a green key appearing in top right hand corner of screen, I cannot delete the photos with this on.
    President:
  • 919 Answers
Protected pictures cannot be erased using [ERASE],
[SEL. IMAGE] or [ALL ERASE], but they are all erased by
formatting.
• Go to Playback mode in the camera. Select the picture to be unlocked with the left or right arrow buttons, and to remove the protection select OFF with the up or down arrow button.
Posted on Dec 22, 2008
How to unlock pictures for olmpus fe-360 as cannot delete photos ,there is a green key on it ...and its lock...how to unlock it.tks
Your memory is probably locked (write protected), There is a switch on the back of the memory card. simply switch it in the opposite direction to unlock it.
Feb 28, 2011 | Olympus FE-360 Digital Camera
I have a picture that has a green key in the upper right hand corner. I cannot delete that picture.
It's protected. Unprotection is the same as protection. While in play mode, go into the menu and look for the "protect" item. Use it on that image to remove the protection and you will be able to delete it.
Comment back if you have trouble finding the menu item.
Feb 11, 2011 | Olympus FE-220 Digital Camera
I hve the write protect problem on my fe 320 olympus. its not allowing me 2 tak pic neither allowing me 2 copy them..
It's most likely that your card is locked. Take out the card and on one side you should find a small slider with 2 symbols (an open and a closed pad lock). Move the slider to the open pad lock position and that should solve your problem. It's a feature on some (mainly SD) cards which lets you lock the card to avoid unintentional deletion of data. Hope that helps
Jul 29, 2010 | Olympus FE-320 Digital Camera
Green key shows on screen, cannot delete that photo
The key means that the picture is locked so you can not erase by accident. You need to remove the key be for you can erase the pic. If you have the manual it will tell you how. if not get me the model of camera and I will get you a manual.
Jan 18, 2009 | Olympus FE-220 Digital Camera
Lock on a picture
formatting.
• Go to Playback mode in the camera. Select the picture to be unlocked with the left or right arrow buttons, and to remove the protection select ON with the up or down arrow button.
Dec 18, 2008 | Olympus FE-220 Digital Camera
One of my pictures wont delete, and the screen says protected how do I change that so I can delete it?
If your pic is in the locked mode (Green Key Icon). Bring up picture. Press menu. Press (Playback Menu) and hit OK. Press OK again and it should bring up the pic with option of off or on. Hit off to unlock and you should be able to delete the pic.
Nov 01, 2008 | Olympus FE-210 Digital Camera
Unwanted pictures
At the top of the camera is a camera symbol and an arrow button. Push the camera button to call up pics and use the left/ right ring where the OK button is to scroll thru. When you get to a picture you do not like push the red garbage can button on the lower right rear of the camera. It will ask you to confirm, then it will delete.
Hope this helps.
Mar 15, 2008 | Olympus FE-220 Digital Camera
Cant remove picture on digital camera
As per the last persons solution the key icon does indicate you have locked the photo. First select the photo you want to delete, press menu, select playback menu, the key icon appears, press the weird shaped arrow button to the right of the OK; phot unlocks and allows to delete!!
Feb 29, 2008 | Olympus FE-220 Digital Camera
Olympus FE-220 Digital Camera Logo
184 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
