Question about Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook
Touch pad not working
Did you ever figure out what was wrong wiht your touch pad? I am having the same problem where I can click sometimes but not really working well. If you fixed it please let me know how. Thanks!
Mouse on samsung laptop touchpad not working
get to control panel right click on mouse open the compatibility tab and click in box and set to your operating system
sometime updating will alter the compatibility rendering the units useless
Oct 21, 2017 | Cell Phones
Touchpad lock
Sounds to me like the touch pad is faulty or contaminated.
Feb 02, 2014 | Lenovo Computers & Internet
My touch pad works with a mouse,but when I tap my touch pad nothing happen's,thats when I lef click my mouse,it will move the icon,but wont tap on toanything
This has happened to me and it took me hours to figure it out. I hope yours is the same problem...
Make sure you dont have your touch pad set to off. On my ASUS It is F9 on my keyboard. the key shows an icon of the touch pad with a slash (/) through it. If you do not see this on your keyboard try looking in control panel and see if there is a setting in there. Good Luck. Please let me know if this worked.
Geraldine
Nov 18, 2011 | Computers & Internet
I recently deleted some old files and temp files to free up disc space and when i rebooted, the scroll on the right side of the mouse pad is not working the buttons are and the double click function is too...
The files in temp folder can be safely deleted and have nothing to do with touch pad atleast. Something else might have gone wrong. Just check from the Device Manager or Control Pannel that the drivers for touch pad are installed. If so, check for the scroll option (synaptics touch pad utility) and set it accordingly.
If it doesn't work, you may download and reinstall the touch pad drivers again from the manufacturers support site.
Hope it helps! Good Luck!
CreativeTECH
Apr 20, 2011 | Computers & Internet
Won't start sometimes, can't set time clock, starts when i touch stop/clear pad, won;t stop unless I open up the door. denmore model 72180413
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 18, 2010 | Microwave Ovens
Touch pad doesn't work
Determine What's Wrong
laptop'smag-glass_10x10.gif touch pad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touch pad may be damaged by excessive use or foreign substances such as water, dirt or food items.
Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return."
Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touch pad to become unresponsive. But if any of these steps fail to remedy the problem, then the touch pad may need to be repaired or replaced.
Repairing/Replacing TouchpadA touch pad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touch pad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touch pad is deemed a necessity, such repairs are rarely worth the cost.
Attempting to replace the touch pad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop.So just attach a mouse to it so you can work easily.Please rate me if this solution works for you
Thanks......Have a great time.
Jul 28, 2010 | Computers & Internet
Cs walked on my laptop. noow cursor pad not working. Help
have a look at the F keys - is possible one of those disables the touch pad
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to claasic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 20, 2010 | Compaq (153515-001) Touch Pad
The mouse pad on my Acer Aspire 5315-2713 is no longer working. I've had the notebook aprox. 1.5 years. What can I do?
Make sure the mouse pad is enabled. Check the manual or web site for your model. Generally, the mouse pad (and other functions) can be accessed by pressing the Fn key + a specific F_ key (1-12).
Sometimes this device or others can accidentally be disabled.
Dec 06, 2009 | Acer Aspire 5315 Notebook
After a power outage, my Amana Gas easy touch control 800 touch panel does not work. The stove lights and clicks when I light a burner so it's getting electric yet the pad clock and oven don't work. Any...
Has it ever worked since the power outage? Have you tried unplugging it for about an hour and then plugging it back in. Sometimes that can reset the control board and solve your problem. I alway like to try the simplest things first.
May 16, 2009 | Kitchen Ranges
Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook Logo
50 people viewed this question
Clive
Clive
Alun Cox
