Question about Porter Cable Portable Generator BSV750
Generator oil for 7500 watt Porter Cable
What type of oil should be used?
    Problem Solver:
  • 13 Answers
15/40 of a name brand
Posted on Jan 06, 2009
What type fuel does a 5250 porter cable generator take
From p.10 of the manual
"Check fuel level, fill as required. Make sure generator is turned off and has been allowed time to cool down. Use clean, fresh, regular unleaded gasoline with a minimum of 87 octane. Do not mix oil with gasoline".
(taken from bottom of this webpage
http://www.cpoworkshop.com/porter-cable-bsi525-w-5-250-watt-electric-generator/pcbnbsi525-w,default,pd.html?cgid=porter-cable-delta-discontinued )
(Is this your exact model ?)
14.April.2014
Apr 14, 2014 | Electrical Supplies
Will not start
That is either valve timing or a failed ignition stator. The stator will send the fire signal to the spark plug at the wrong time and hence the backfire.
Dec 06, 2011 | Porter Cable BSV750W 7500 Watt Electric...
Throttle on generator question
The idle control switch allows the generator to go into idle when there is no demand form the appliances connected. This saves gas and increases the life of the generator. Damage can occur for some appliances like a refrigerator/freezer because the voltage and frequency are not prepared for the load resulting in a low voltage bad startup that will damage the appliance. Suggest that you leave the idle control switch off while any motor/electronic devices are connected.
The throttle control is likely a choke function for starting. These generators are designed for only one running speed to produce the necessary 60 cycles per second and voltage.
The following link is to a Canadian web site that later in the detail report describes the concern of idle control. In addition it provides good insight to the operation and use of portable generators
Hope this helps?
Understanding Portable Generators
The user manual see pages:
http://www.mikestools.com/download/Porter-Cable-Manuals/Porter-Cable-CTE300.pdf
May 06, 2017 | Porter Cable Portable Generator BSV750
What type and weight of oil do you use
Porter Cable recommends straight 30 weight synthetic oil for their engines. However, If you live in a colde climate or in a hot climate, the use of multi-viscosity oils is my recommendation. Straight 30 weight oil in my cold climate would not work. So, it really depends on where you live.
30/5 works well in a cold climate like mine.
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | Porter Cable 5,500 Watt Portable Generator...
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
My porter cable generator 3000 wt will not stay running once star
If this generator has been stored for any length of time with fuel in the carb you probably have a plugged main jet in the carb. As joboo1 says there are a few other things that could cause this behavior, but most often I see dirty carbs, water in the fuel, and plugged/dirty air filters. Get a flashlight and look into the fuel tank thru the filler hole, if you see anything floating in there you've got water in the fuel. Look at the ari cleaner, oil and fuel on the element indicate a dirty carb. Of course check the oil level. Lastly, take the bowl off the bottom of the carb (shut off the fuel valve first), if you see debris in there the carb needs a good cleaning.
Regards,
Carl
Feb 23, 2009 | Porter Cable 3,000 Watt Electric Generator...
Porter Cable Portable Generator BSV750 Logo
200 people viewed this question
Top Porter Cable Welding Tools Experts
Craig Butler
Craig Butler
Robert Monigold
Robert Monigold
jhnolson
Are you a Porter Cable Welding Tool Expert? Answer questions, earn points and help others
