Question about Averatec Computers & Internet
The laptop does not start up
I try to turn on the PC, but it does not turn on, the Fan does not work and the Hdd is stoped, moreover there any picture in the screen (it is always turned off)
there's only the first led working (the power led), the others does not work ( HDD led at the begining work, but 2 seconds after turned on... it is off)
It does charge (the led works), however there are any signal of life.
Could you help me with this issue?
the model laptop is AVERATEC 3700 Series
Serial: NS02CE050902342
Unfurtunaly I bought it in USA, but I'm In Costa Rica, Central America Righ now
Thanks in advance for your support
  • oelalva Dec 19, 2008
    Actually I've done it few time ago, I've connected a extra monitor in the video port (VGA), however it does not send any signal.
    I know there is energy because I can open the DVD bay when I press the button.... but it seems that the energy is not distributed to the monitor and HDD.
    is it common in this kind of llaptops this issue?
    Any help you could give me would be greatly appreciated
    thanks in advance for your time!! :)
    Regards,
  • 60 Answers
Try taking the battery out for 15 or so minutes. plug the lappy into pwr like this and try turning it on.
if this fails hold the pwr button down for approx 15 sec then just push it once.
Posted on Dec 19, 2008
Hp 6730b gets hot quick..what to do?
Remember Laptops are delicate and it is avoidable to open them.
Especially if you are not a technician or knowledgeable about them.
Try and remove the dirt from the fan using a low power vacuum from outside.
Use a cooling pad Laptop Cooling Pads
and save yourself the risk of a working laptop.
Moreover I suggest get the internals cleaned when you undertake a upgrade for example HDD to SSD
Sep 30, 2016 | HP Computers & Internet
Why my acer ferrary one 200 turn on, but no monitor/display, no hdd led flashing
If you are able to hear the fan running inside your laptop , then it should be possibily the mother board that needs to be checked.
Aug 11, 2014 | Acer Ferrari ONE 200-1799 Notebook
Help Black screen fan but no hdd light
No display and not booting after getting very hot is likely to be a GPU issue. This is repairable.
Jun 02, 2014 | HP Pavilion g7-1310us 17.3" Laptop
I am unable to format and reinstall windows from pd or dvd saying disk error.Moreover when playing games it gets overheated and game stsrts to freezealso processing is quite slow although task manager show...
Try cleaning out the CPU cooler. Sometimes they get too much dust in them and they cant cool the computer correctly. Blow out the vents on the side or back and you will probably see the dust come out the intake for the fan. Blow out the fan and then the vents again. Do this till you dont see dust come out. Canned air works but I use an air compressor and filter on the line. The i7 runs hot when you game. You may also need to try to put a cooler under it. Try that and see what happens.
Hope this helps... Dale
May 08, 2011 | Dell Xps 14 Laptop Computer (Intel Core i7...
Nx5000: Won't power up. symptoms:battery does not start(believed to be dead). Mains power,starts up and shuts down on a continuous 3-5 second cycle, from the time you switch mains on at wall. The...
Hi whisky_zulu,
I see that you have basically done everything possible on the machine still to no avail.
Basing from what you've done still the issue is the same it shows that the motherboard on the machine needs to be replaced.
no beep codes as you mentioned indicates that the motherboard does not respond at all there maybe power but you also mentioned that it also shuts down once turned on for a couple of seconds.
replacing the systems motherboard will be the only solution to this issue.
I hope that this makes it clear regarding your query.
Have a nice day,
mvincentc
May 07, 2011 | HP Compaq nx5000 Notebook
Dell 1320 caps lock led flashing and next hdd and fan go off and no boot
you have to change the fan of the hard drive cuse that make you lap stoped
Sep 28, 2010 | Dell Vostro 1320 Notebook
Dim screen, mouse/keypads doesn't work and the dvd/cd drive doesn't work
INCREASE THE BRIGHTNESS OF YOUR SCREEN THROUGH PROPERTIES OF SCREEN AND CHANGE OLD KEYPADS AND MOREOVER REMOVE DUST STICKED BELOW YOUR MOUSE.
Dec 06, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Seems the HDD starts turning then stops again and again, check power supply good,exchange power supply ..does not fixed the issue.
dear,
did u feel any noise over there.. or just stoping again and again without noise??
in both cases, mostly the issue related with the spindle motor inside the hard... you need to check it..moreover,, check if the main ICs on the card is heating...if yes, then u have to replace the card not the complete hard...
Aug 03, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
My laptop shuts down everytime i play games on it ..heats up..
please check the vents and try to clear them up if choked. Moreover please check the fan underneath your laptop that it is functioning properly. If not get it replaced and if it is working properly try connecting one cooling stand or a docking station with cooling functionality in it.
Jul 11, 2009 | Acer Aspire 5315 15.4-inch Notebook PC
Computers & Internet Logo
131 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
