Question about Dryers
Clothes are getting caught on edges of drum
Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks. Dryer makes "gravely" sound when turned on.
  • 1 more comment
  • Cliff Rohner Dec 26, 2008
    I have more or less the same issue, clothes in particular things with buttons are getting caught between the drum and door.
  • wadeandrober Apr 01, 2009
    how do u replace the felt
  • Anonymous Mar 15, 2014
    model #FSE748GFS0
  • 179 Answers
You need to replace the felt on the dryer
Posted on Dec 20, 2008
I have a whirlpool wed5520sq0 dryer the drum seems to be pinching cloths and making marks on them. The drum has a gap on left side looking into the dryer. I can move it and close the gap. Any ideas would...
Sounds to me like either the seals on the front and back of the drum are worn or the glides for the drum are worn and is causing the clothes to get caught between the drum and the usually the
front edge of the dryer. The worn glides will cause the gap that you mention.
Feb 11, 2011 | Whirlpool WED9200SQ Electric Dryer
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My crosley dryer is making a terrible scraping noise. I lifted the top of the cover off and could see the drum. There are several scrape marks in a few spots. Obviously it is rubbing on the bottom. What is...
The first thing to check is whether there is something caught in the drum rim (both front and back). Feel around the circumference of the drum in both places for a piece of clothing or pocket item jammed in there. If all is clear, then most dryers have drum glides on the front that will wear. Those aren't expensive and not that hard to replace for the mechanically inclined. A bad rear support roller is also a possibility. To replace it , the drum will probably have to be removed. Drums aren't that hard to get in and out, depending again on your mechanical ability. Hope that helps
Jan 02, 2010 | Crosley Dryers
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
My clothes have brown marks on them that look like burn marks. has this been a problem with maytag neptune dryers? if so, what is going on?
Rollers
Rear seal
Front glides
Front seal
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Frigidaire Dryer. Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks.
Open the dryer door. Reach in just inside and feel for the felt seal that goes all of the way around the drum. The culprit is usually the top portion of the seal which supports the end of the drum near the door is worn out. This allows the drum to tip down and leaves a gap at the bottom. Clothes get caught in this gap and get rubbed and marked or rubbed clear through. Remove the front of the dryer and replace the seal. On some models the top 1/3 is replaceable. This portion carries the weight of the drum and is what wears out.
Jun 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Brown marks on the clothes
Yes, the felts are what seals the unit and allows the drum to turn without much heat loss. The felt can become damaged and the clothes will get caught between the drum and the housing leaving these marks.
Apr 09, 2009 | Kenmore Elite HE4 Electric Dryer
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer damaging clothes
Call repairman if you are not mechanically inclined it will be worth the money spent.
Oct 29, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
399 people viewed this question
Top Dryers Experts
Marvin
Marvin
