Question about Sony VAIO FRV28 Notebook
Memory upgrade from 512 to 1,024 problem
I am trying to upgrade from the standard 2x256Mb config to 2x512Mb. Laptop will only recognize one of the 512MB chips. Is there a setting somewhere or driver/bios update I need to complete this?
  • Trevor Balman Mar 31, 2007
    yes they are a set of Corsair 512mb PC2100 sku# VS512SDS266. I have swapped them between the two banks in my laptop to no avail. I still only get 512mb of 1gb to register under Windows XP Home system info.
  • 86 Answers
Well, it seems that both RAM sockets worked previously with the 256MB DIMMs; remove the 512MB DIMMs, and install the two 256MB DIMMs again, then boot the system to see if both of the smaller DIMMs are recognized. If BOTH are recognized, then one of the 512MB DIMMs is defective; test each one individually to see which one is not working. If only ONE of the 256MB DIMMs is recognized, then you might have a small piece of dirt or debris in one of the DIMM sockets; it is also possible (though not as likely) that one of the DIMM sockets has recently become damaged while you were changing the DIMMs... Shut the system down, REMOVE THE BATTERY AND POWER CORD, then examine each DIMM socket to see if you can find any dirt or debris blocking the DIMM from making proper contact in the DIMM socket. Also be sure to check the DIMMs for damage, or the presence of a foreign substance on the gold contacts. You can use a pencil eraser to GENTLY clean the gold contacts on the DIMMs; this will help to remove any light surface oxidation that could be causing this type of problem. Post here again to let us know what you've learned...
Posted on Mar 31, 2007
  • 385 Answers
Are both of the ram PC2100? Because this mother board only supports PC2100 memory modules.
Posted on Mar 30, 2007
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory seems that your laptop could only accomodate max 1Gb of RAM
Feb 14, 2010 | Gateway MX3215 Notebook
I installed 2x512mb DDR266 modules on my P4i45gv motherboard but in the bios and in winxp it only shows as 2x256mb memory odules.Why is this and how can i fix it?
You might have a board there sir that accepts a certain speed at that size now if the spec does not match up then your board will only accept 256X2
Aug 14, 2009 | Asrock P4I45GV R5 Motherboard
I want to upgrade my memory. my current memory is 2x256mb pc2 3200. what is the max limit of memory can i have? is it per slot or total? if i get pc2-5300 is it backward compatible to pc2-3200? anyone with...
You can have a maximum of 2GB in that laptop 1x1GB in each slot, the ram speed is PC3200, PC5300 is too fast so the bios will not recognize it as the maximum is only 400MHz, stick to the PC3200 for each stick.
Ask for SODIMM DD2 SDRAM, PC3200 2x1GB, i also recommend Kingston as the ram manufacturer.
Aug 01, 2009 | Dell Inspiron 6000 Notebook
The memory I install to Armada wont boot
You CAN NOT mix 100 and 133 chips! It is not good for the computer. They may let the computer work, but it won't recognize them properly.
If you still want to use the new chips, try and bypass the acklowledgment. Don't know if it is possible, but it may be the only way.
You should be using the correct chips.
You can go to: or to find out what sizes your computer is allowed.
Jun 01, 2009 | Compaq Armada E500 Notebook
RAM not found as 2x512MB
Are you finding these number when you go into your bios or from a program such as CPU-Z? If you are using good quality DDR400 memory, it should be posting with the full amount of memory available. You are using the correct slots to get dual channel, but you may want to try slots 1 & 2 or 3 & 4 to see if it will post with the full amount of memory as single channel. You may also want to have a friend try the memory in their computer to see how it posts, you may have some bad memory.
Apr 05, 2009 | Intel D865GBF Motherboard
Verify memory upgrade in a Inspiron 1200
Verify on the label of the the memory Dimm that you installed that it is PC2700 SDRAM.
Memory Upgrade for Dell Inspiron 1200 Laptop, the Dell Inspiron 1200 Laptop takes the PC2700 DDR SDRAM SODIMMs. Memory Type, and comes installed with 256 MB (non-removable) of Memory. You can upgrade your Dell Inspiron 1200 Laptop to up to a maximum of 1280 MB Memory, the system has 1 socket to install Memory, already with 256 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Standard Memory 256 MB (non-removable) Maximum Memory 1280 MB Memory Expansion 1 socket Memory Comments PC2700 DDR SDRAM SODIMMs. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 27, 2008 | Dell Inspiron 1200 Notebook
1st......Operating System?????
2nd.....Run Device manager to ascertain RAM installed
3rd.....Download Sandra Lite to find M/B specs.(Free Download)
4th.....Check if RAM is SODIMM,SDRAM,DDR,etc
5th.....Open PC case to ensure RAM slots available.
6th.....Purchase correct RAM.e.g.128MB->256MB,256MB->512MB,512MB->1024MB
Check to see if RAM slots are paired or not
If paired....2X128MB=256MB
Feb 02, 2008 | HP Pavilion MX75 17" CRT Monitor
Memory upgrade
no jumper just touchy mobo on ram u buy u have to buy ram off ebayt samsung low denstity 64x64 chip config ok like i did and it workeed mark this as fixed ya so others can get same help thx nick
Jan 30, 2008 | IBM NetVista M42 PC Desktop
Memory module
Your motherboard supports 533MHz memory modules, no more. If you put anything higher in, it will work, but only at the speed of 533MHz, so there's not much point in aiming any higher. Just make sure what you're buying is a DDR2 533MHz memory module, and it's best to get them in increments of 2. If you have 4 slots on your motherboard, get another 2x512MB modules of RAM. If you're running Windows Vista, it might be worth considering 2x1GB modules. I think that pretty much covers your question, if you have anything else to ask, feel free to reply.
Sep 07, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Sony VAIO FRV28 Notebook Logo
134 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
