I have an mtx ta7804 amp. Its a 4 channel amp that i have bridged to 2 channels. Its RMS is 800 watts and peaks at 2400 watts. Its powering two 12 inch 7500's. I have had this setup in my car for about 6 months now and it has been working very well up until about the last month. The sound being outputted has slowly been deceasing and now when i turn up my remote gain i can definetly tell that its just not as good or loud as it used to be. I do not a have a cap and my battery is not low at all. The livewire inline fuse is not blown and nor are any of the 3 fuses on the amp. What is the problem?
    President:
  • 624 Answers
Can you check the amp with a pair of different speakers? It may just be the speakers are starting to go bad. Let me know and I will help you further if needed.
Posted on Feb 06, 2009
Will the amp blow my speakers?
If you bridge the amp and get 1000 watts RMS and that is split going to two speakers then you will get 500 watts RMS at each speaker. If you have your amplifier on maximum gain it may blow your speakers, not because they are overpowered but because you might run into "clipping" issues running the amp at maximum capacity. Just to be safe I would dial the amp's gain down to 3/4 of the way to full gain. That should give you ample power and keep your amp from clipping and running hot.
Aug 11, 2015 | MTX Car Audio & Video
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
How many watts is this amp
Specifications Power Output: 100 Watts RMS x 2 channels at 4 Ohms ≤ 1% THD+N Signal-to-Noise Ratio: 80 dBA (reference: 1 W output) Additional Power Output: 200 Watts RMS x 2 channels at 2 Ohms ≤ 1% THD+N
400 Watts RMS x 1 channel bridged at 4 Ohms ≤ 1% THD+N THD+N (Distortion): <0.25% (reference: 1 W output) Frequency Response: 20 Hz to 20 kHz (-3dB) Maximum Input Signal: 5V Maximum Sensitivity: 100mV Dimensions: 14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
Jan 03, 2010 | MTX 4002 Car Audio Amplifier
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
I have 3 hifonics zeus Size: 12 inch Impedance: Single 4 Ohms Peak Power Handling: 800 watts RMS Power Handling: 400 watts Sensitivity: 89.9 dB Aluminum Cast Basket American Spider For Reliable Performance...
Hello king3132,
Three 4 ohm subs can be wired parallel for a 1.34 ohm final load or series for a 12 ohm load. If you have the channels of the amp bridged, I hope that the subs are connected in series because the Sony XM-2200GTX is NOT rated for or stable at 1.34 ohms. It's only stable down to 4 ohms.
You definitely will not get the maximum potential of the subs from that amp. They can handle 400 watts RMS each (total 1,200 watts) and the amp is only capable of 500 watts RMS into 4 ohms (less at higher impedance), so each sub could only be getting a maximum of 166.6 watts RMS.
Hope this helps.
Jul 20, 2009 | Digital Audio Car Audio & Video
Mtx audio 4252 amplifier
Hello freshman_fox,
63 watts X 2 @ 4-ohms.
125 watts X 2 @ 2-ohms
250 watts X 1 @ 4-ohms bridged
Since no power rating is given @ 2-ohms in bridged mode, it means that the amp is only stable to 4-ohms.
The manual does not specify a peak power, but since RMS is about 70.7 of peak, that makes it 353.5 watts.
You can download the manual from here. Hope this helps.
Jul 10, 2009 | Car Audio & Video
I have a kicker zx700.5 amp
Hello aj_vidal22,
Here's the link to MTX's sub page where you can view or download the information you need to properly wire the subs to your amp.
http://www.mtx.com/caraudio/products/manualsQuickInstall/subs.cfm
For maximum power, you'll need to wire the subs so that they present a 2 ohm load to the sub outputs on your amp. That will give you the full 420 watts RMS the amp is rated for. Likewise, you,ll want the run the front 4-channels at 2 ohms. Run separately, they produce 85 Watts times 4 channels, or if bridged, 130 watts times 2-channels. But if you run fronts at 4 ohms, they only produce 70 watts times 4 channels and your sub output at 4 ohms drops to 210 watts.
Hope this helps.
Apr 17, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
 Grubhead
Grubhead
