Question about Sony KP-53V75 53" Rear Projection Television
2 separate colors on screen
Wavy image on the right and left sides, 2 separated colors, red and green, overlapping. The middle of the screen is not wavy. Happened without any noise or indication other than suddenly happening. The TV is about 7 years old, rear projection Sony, model KP-57WS500
  • mozarkexpres Dec 19, 2008
    the images have a rainbow discoloration on the screen,
    red and green on the side, wavy but the middle is fine.
  • Anonymous Mar 09, 2009
    3 separate color on screen
    Sergeant:
  • 233 Answers
Sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 19, 2008
I have a RCA 52inch hdtv that has three color lines red green and blue at the top of the screen together and then they separate. It turns itself on and off. And the images on the screen appears to be three...
Go to Menu then setup ,Do you see Convergence, If not then you have a Blowed Fuse on the Deflection Board FL231. Deflection board will be the bottom lefthand side with FBT flyback transfomer on it and on the right hand side of FBT is 3 Fuses in a roll but they do not look like Fuses they will be small rectrangler looking caps but are Fuses it will be the one in the Middle. .06amps. If you have anymore question let me know . Thank You
Jun 27, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
3 screen colors have separated and screen is bowed in the middle.
I take it this is a projection TV. so they use three lensed CRTs red green and blue. you should have a setup screen that projects a grid pattern. red green and blue. there is SOMEWHERE a adjustment that overlaps the three projected grid patterns. Making a WHITE single grid pattern. red green and blue make white light. Pin cushioning is the bowing. you may find a POT to adjust on the back of the set. I have no idea what set you have.
Lastly.. Pin cushioning can also be caused by faulty flyback transformers.
Hope I could help.. new here LOL
Happy Fixing =)
Jul 12, 2009 | Televison & Video
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Red and green have separated. is this fixable?
yes this can be fixed
it is the convergence IC's that controls each color image alignment ,also other components(resistors , diodes , capacitors , ect..) in circuit with these convergence IC's(STK's) also need testing to see what other component has also failed or needs replacing.
Mar 19, 2009 | Zenith R57W46 57" Rear Projection...
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Pioneer Pro-119 Rear Projection TV
HEY DF-YOU SET HAS 2 BAD STK392-110 CONVERGENCE ICS.THEY WILL NEED TO BE REPLACED AND IF NO OTHER CONVERGENCE CIRCUIT PARTS HAVE FAILED YOU SHOULD BE ABLE TO SET YOUR CONVERGENCE ALIGNMENT PROPERELY.TV REPAIR ESTIMATE SHOULD BE ABOUT 300.00$.DO IT YOURSELF FOR ABOUT 40.00$.
Nov 24, 2007 | Pioneer PRO-200 60" Rear Projection...
Sony 65 Inch Projection TV Color Red Green Separation
Sounds like a convergence issue. Call Sony for an ASC that can come out and give you an estimate. You are probably looking at $200-400 to do the repair.
Nov 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Sony KP-53V75 53" Rear Projection Television Logo
292 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
