Question about Mitsubishi WD-52528 52" Television
Colors are off (NO YELLOW. BLUE) has a Green Hue to picture
Mitsubishi WD 52628 HDTV cannot correct the color, colors are off, it did funtion properly once and then went to green color. Was moved recently via truck and that is when the problem started.
    Genius:
  • 1,030 Answers
There may be the possiblity of loose dvi cable between chasis and optical enngine. this is a cable much like a montor cable. it has two screws that tighten it down. reseting this sometime help
Posted on Dec 19, 2008
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Colour prints coming out with a lilac hue
check whether the printer is in proper mode or not
Feb 29, 2008 | Epson Stylus Photo 950 InkJet Printer
A blue hue started in the lower left corner and over some time covered the whole screen giving it a yellow/green color.
GET ON EBAY AND LOOK UP THIS GUYS STORE TVBSERVICE, HIS NAME HONG BUI E-MAIL HIM WITH YOUR PROLEM AND HELL FIX IT FOR YOU , HE FIXED MY PROBLEM FAST AND CHEAP
Aug 05, 2010 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
I have a zenith lcd projection tv 5yrs old. replaced the bulb last august. It has started to develop a green hue across the screen. it is random, but quite annoying. and confusing. I would appreciate any...
Don't know the exact problem, but typical projection tv's get very dirty and this may affect picture clarity, contrast, and perhaps color, including overheating of components. Make sure you have good airflow, clean filters, and a projection lamp that is free of contamination and finger prints. If you have a setup function, check the colors for purity and integrity
Jun 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Color problems
Your color wheel is bad. Thats the only thig that controls color on the DLP projections. You will need to replace it But I would check the connections on it first to make sure the connections are secure. Let me know if you require more assistance.
Feb 26, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Colors are off after auto adjust
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Dec 05, 2007 | AOpen 19" LCD
Mitsubishi WD-52528 52" Television Logo
243 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
