Question about Bose Acoustimass 10 III System
Subwoofer humming/buzzing I recently bought a Samsung 58" Plasma TV, which replaced a Mitsubishi 46" HDTV and the subwoofer produces a very audible humming or buzzing only when we watch TV coming through the cable box. When I watch a DVD or listen to a CD through the Bose surround sound system the humming is not present! I've replaced the cable from the wall to the cable box and the audio (red/white) cables from the TV to the Bose system with higher quality, "shielded" cables and have attempted a number of connection configurations with the same end result. Anyone know what I can do to stop this problem!
  • 69 Answers
It sounds like one of the internal solder welds to the cable or a/v connections inside the cable box is bad.
Posted on Dec 19, 2008
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Loud buzz in sub woofer, soundbar sounds fine
How to Stop a Subwoofer Hum - HowStuffWorks
electronics.howstuffworks.com/how-to-stop-subwoofer-hum.htm
Would you like to learn how to stop your subwoofer from making a consistent low-frequent hum or buzz? Read this article to learn how to stop a subwoofer hum.
Aug 03, 2015 | Audio Players & Recorders
Subwoofer is hummig what is this noise
Hum is a constant low-frequency buzz, usually at about 60 Hz or 120 Hz, which results from voltage differences between true "ground" (what you'd get shoving a copper pipe into the ground) and the electrical "ground" of your receiver's chassis When this voltage differential exists, it's called a "ground loop," and the hum it produces is darned annoying. You'll hear the hum mainly from the subwoofer because it's a low-frequency noise, you will need a ground loop insulator they are about $20 at any electronic store
Dec 28, 2013 | Vizio 2.1 ch. Sound Bar with Wireless...
I hear a humming noise from my Sunfire subwoofer - occassionally. I bought a kit from Radio Shack that supposed to cut down on noise from the electric outlet - it didn't work. Please help!
How to isolate annoying background hum.
As long as the music or movie is playing, you can forget about it, at least until a quiet passage occurs, then there it is again: HUMMMMMMM! Be gone, bad hum, you think. But, like a bad odor at the back of the fridge, it takes some dogged persistence to track it down and eliminate it.
Hum is a constant low-frequency buzz, usually at about 60 Hz or 120 Hz, which results from voltage differences between true "ground" (what you'd get shoving a copper pipe into the ground) and the electrical "ground" of your receiver's chassis, the incoming cable-TV feed, or any video or audio components interconnected within your system, including powered subwoofers. When this voltage differential exists, it's called a "ground loop," and the hum it produces is darned annoying. You'll hear the hum mainly from the subwoofer because it's a low-frequency noise, but there will also be hum from your floorstanding front speakers or even compact bookshelf models.
First, try disconnecting your subwoofer from the coaxial sub cable from your AV receiver but leave the subwoofer turned on. Does the hum go away? If it does, then the ground loop is entering the system from your AV receiver and/or your cable-TV system set-top box (or satellite dish and decoder).
Disconnect the incoming TV-cable or satellite feed to a set-top box or to your TV and the A/V receiver. If the hum disappears (and you don't use a satellite dish) complain to the cable-TV company. They may know what you need and supply you with a ground-isolating transformer. If they don't know what you are talking about you'll need to order a video ground isolator and install it in-line with the TV cable before it enters your set-top cable-TV box. Axiom has special wide-band isolation transformers that will not interfere with any digital TV or HDTV signal. (N.B. You CANNOT use one of these with a satellite decoder box.)
Before you order one, you can try plugging your subwoofer into a different AC outlet in the room, ideally one that is not on the same circuit as your AV receiver and video equipment (TV, DVD player, sat or cable TV box, etc.) That may solve the problem. If it doesn't, see if the back panel of your sub has a "ground-lift screw". It will be labeled as such. Just remove it. That may remove the hum. If it doesn't and you have a standard cable-TV feed (not a dish), then order the ground-isolation transformer. (Axiom has special wide-band isolation transformers that will not interfere with any digital TV or HDTV signal.)
Axiom Audio Ground Isolator
If that still doesn't eliminate the hum, or if you use a satellite dish video feed, then you could try one of these from Radio Shack, which goes between the subwoofer and the coaxial cable from the receiver's subwoofer output.
With persistence, all ground-loop problems can be solved.
Hope it helped..
Have a nice day...
Feb 21, 2011 | Sunfire True Sub MK II Subwoofer
After a power outage I have a loud hum.
Hi, The Ground Rules Of all the annoyances that can afflict any audio/video home theater or even a simple stereo installation, the notorious "ground loop" may well be the most difficult and persistent one to track down and eliminate. A "ground loop" is caused by the difference in electrical potential at different grounding points in an audio/video system. (All the grounds in an A/V system should ideally be at "0" potential.) A ground loop typically adds a loud low-frequency hum or buzz as soon as you plug in any of various audio or video components, including subwoofers, cable-TV outboard boxes, satellite-TV feeds, TV displays, amplifiers, A/V receivers or turntables. The buzz/hum is a byproduct of the multiple power supply cables and a ground voltage differential within your system and its network of interconnecting cables.
Here are some methods to help you get rid of ground loops. Try these first and don't waste money on a power "conditioner" which, in most cases, won't help. (There is no need to "condition" the AC power for your system. Your receiver or amplifier already has a power supply with its own filters and transformers. No further filtering is normally required.)
If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your cable-TV or satellite-box feed at the entry point to your system.
First, the subwoofer: unplug the coaxial cable that connects to your powered subwoofer to see if the ground-loop hum disappears. If it does, it's likely coming in through your cable/satellite TV feed.
Reconnect your subwoofer's coaxial cable from the subwoofer input to your receiver's subwoofer output and disconnect the cable-TV feed (or satellite feed) from your outboard set-top cable box or satellite tuner. Be sure and disconnect the cable before any splitters. Now see if the hum/buzz from your subwoofer stops.
If that eliminates the hum, you can install one of these inexpensive in-line ground isolators from Parts Express or Bass Home. Note that these transformer-based ground isolators will work fine with analog cable-TV feeds, but depending on their design they may interfere with or block reception of HDTV signals via a digital cable or satellite dish feed.
Install the ground isolator between the cable-TV feed and the input of your outboard cable-TV box or satellite tuner (or the TV display's antenna or cable input if you have a set with a built-in TV tuner or a cable-card ready set). In many cases, the ground isolator will "break" the loop and remove the annoying hum or buzz by isolating the TV-cable ground.
If a hum remains with the TV cable completely disconnected from your system, or you don't want to risk degrading reception of HD signals from a cable or satellite system, then you may have to add a ground isolator like this Radio Shack Model 270-054 between the line-level coaxial subwoofer cable from your A/V receiver and the line-level input jack on your powered subwoofer.
In all cases, if your subwoofer has a ground-lift screw like some of Axiom's subwoofers, try first removing the screw (or replacing it) to see if it increases or eliminates the hum. It may or may not make a difference.
If you do not have easy access to the aforementioned ground isolators, here are a few more tips:
Try plugging the subwoofer into a different AC outlet in the room, one that isn't supplying power to your components (A/V receiver, TV, cable box, etc.). That might fix it.
Try reversing the AC plug for your A/V receiver or the powered subwoofer. If it's a 3-wire plug or a polarized plug, which has one prong wider than the other, you won't be able to reverse the plug. For safety, do not use a "cheater plug" to bypass the 3-wire plug.
With the power OFF, reverse the AC plugs one by one of any other components that have a standard 2-prong AC plug that isn't polarized. Each time you reverse a plug, turn on the system with the attached component and your subwoofer and see if the hum disappears. In some cases, reversing one or more plugs will eliminate the hum.
If you have a turntable, try connecting a separate ground wire to a chassis screw on your preamp or receiver and see if the hum disappears. If you already have a turntable ground wire, try removing it from the preamp. One or the other may eliminate the hum.
Finally, here is another solution that worked well for a member of our message boards who decided to discard his ground-loop isolator on his subwoofer: "I took off the ground-loop isolator I'd been using and connected a plain 14-gauge wire to chassis screws on the sub and the receiver then powered everything on. Although hum was still there, it was far lower than before. Next I unscrewed the ground-loop screw on the back of the sub and that took care of the hum completely."
Almost certainly sounds like an earth loop to me, but can be caused by a poorly made transformer or phase shifts on the mains supply. Visit some power conditioner web-sites like Isotek or Isol-8 (or google "earth loop") where there's plenty of advice on how to reduce/eliminate earth loops and other causes of mains-induced hum (transformer problems etc).
Hum on the speakers usually indicates that there is a DC voltage on the speaker line. DC voltage on the output lines would be caused by a shorted output transistor.
Have a nice day...
Feb 16, 2011 | Cambridge Soundworks BassCube 12 Speaker
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
I recently connected my satellite reciever to my
Iassume you mean you hear the buzz independently of the audio program - simply connecting the cable causes the buzz?
If tanything in the mix is powered from different AC sources you may have a different ground potential. Sometimes manipulating the orientation of one or more ac plugs will solve hum problems.
Apr 02, 2010 | M&K Sound Mp Series MX-350 MK II THX...
Subwoofer problem
If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your reciever feed at the entry point to your system.
Dec 23, 2009 | JVC RX-6018V Receiver
We have a samsung hdtv monitor. Bought bose
you can try checking in your t.v.s menu for audio program
Sep 19, 2009 | Samsung Audio Players & Recorders
Bose Acoustimass 10 III System Logo
1,134 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
