Question about Plumbing
Behind every cycle it comes to an indication ''LE''
What does '' LE '' mean?
Please can you send me a Troubleshoting of this Model?
Washing Maschine DAEWO DWF 8002P
  • 23 Answers
The code LE is for motor overload protection.
Ensure that you are not overloading washer, make sure to clean pump by draining at little door at lower left corner(check manual for instructions), unplug for 30 minutes to reset, now try running cycle again. if it fails again something else is causing the motor to work to hard and will require a professional.
Posted on Apr 29, 2009
My name is raza. i have west point washing machine model no 1225tl , Fix error LE is coming. please tell me about this urgent.
An LE error code on the washer's display indicates that the motor is locked, possibly due to a heavy wash load.
Large and heavy sized loads will put a strain on the motor, causing the LE code to occur. Performing a reset on the washer will normally resolve this error.
To reset the washing machine:
  1. Press POWER to turn the washer off
  2. Unplug the washer from the power outlet. If the outlet cannot be reached, turn the circuit breaker to the unit off.
  3. With the power disabled to the washer, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in, or turn the circuit breaker back on.
The washer should now be reset and the LE code cleared. If washing a heavy or large load, reduce the load size and attempt to restart the cycle.
Note: For your safety and to preserve your warranty, if the issue persists, LG recommends that all repairs are performed by an Authorized Service Center.
Jan 06, 2017 | Washing Machines
Why do all lights flash when machine is turned on and unable to start the washing?
The number of times that the lights flash is the trouble code. Your machine is in need of repair.
Nov 21, 2015 | Washing Machines
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
LG WM2350HNC Front Load Washing machine displays LE error, I have tried cleaning it and flushing the drain hose out and the filter., still will not work... Tub tries to spin but can't... It is only...
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. What is the model number listed on the machine? The number posted was for a range.
Nov 14, 2012 | Washing Machines
When i started my machine after play for washing its showing LE on display
You didn't state the make or model of your machine, but I'm guessing that it's an LG machine (It's the only one that I can think of at the moment that produces an "LE" error.
LE Means LOCK ERROR - the trouble shooting information says this means taht the lead wire assembly is not connected. What this actually means is that the little switch that is sat behind the door catch that locks the door shut once the cycle starts isn't working. Most likely because a wire has fallen off the back of the switch, or the switch has failed open circuit.
If you take the lid off the machine and tip it back so you can get a clear look at the casing of the machine from the inside, you should be able to see the switch immediately behind the door catch that you can see from the outside. If you're lucky, you will see a connector, hanging in the air where it has come off a spade connector on the switch. If you're unlucky, the switch may need replacing, if you're really unlucky, the wiring may be faulty somewhere.
Jun 29, 2011 | Washing Machines
Front loader won't spin, just after 2 mins up into the cycle it comes up with message le. Can you help please?
Hi just read your posting.Now I need to know the make and model of your machine.It sounds like you have an LG front loader.LE on the LG front loaders means your HALL SENSOR which is attached to your motor is faulty.Please reply with model number and I am sure I can help you.Looking forward to your reply.
Sep 11, 2010 | Washing Machines
LE sign comes on
over suddsing is what this erro indicates. Clean the pump out as well as the hoses and use less soap.
Please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | LG WM-2277HW Front Load Washer
Le error what does it mean?
Initially unplug the washing machine.
While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
If you still face problem then follow the procedure :
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps .
Apr 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Turned on my washer a TROMM LG wm2277hw and at every cycle turn it beeps LE
LE means a faulty motor. The motor is called the "stator" in this machine. Located behind the back panel. Pretty easy to replace in this machine. Replace the stator and it will work like new!
Apr 07, 2008 | Washing Machines
Plumbing Logo
42 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
