Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525, replaced bulb but still not working
The red light was on so I bought a new bulb and put it in. Pluged up the TV, waited until the green timer light went out pressed the power button. The fan came on, but no picture. After a minuit or so, the red light came on again buring solid. What is the likelyhood that the replacement lamp was bad? Additionally, I removed the lamp cover and placed a plastic piece in the hole to close the switch so I could see what was going on with the lamp. after the fan comes on for a few seconds, the bulb lights up for about 10 seconds and then goes off. After a minute or so, the red light comes back on. What do you think is going on?
  • jberry11111 Dec 19, 2008
    So you think the FMT PCB might be bad? Does this mean the bulbs are probably good? I am debating on whether or not to send the bulb back and get a replacement (however, if they test it and the bulb is good, I will get charged).
    Additionally, is it common for the bulb to come on for a few seconds when you first press power and then go out?
  • jberry11111 Dec 20, 2008
    you are exactly right, C9A37 and C9A38 are both bulged. What do I need to do to fix this? Any idea of the cost?
    Genius:
  • 1,030 Answers
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
this is what we at the shop check first. it is quite common. on the power supply board look for swelled up capacitors
Posted on Dec 19, 2008
  • Willie Howell Dec 19, 2008
    if the new bulb comes on breifly i would have to say its probally good. i would still point my finger at the capcitors on power supply board.
    check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB
    (part # 930B921002 look for swelled up capacitors this is the first this is the first thing mitsubishi technal recomends
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replaced bulb in Mitsubishi WD-52525 and it still does not work
What does not work? Does the green light flash or light at all? Can you "manually" turn on the tv? If the light is RED...the replacement was either installed incorrectly (or is not plugged in correctly to the contacts at the rear) or is the wrong bulb. Be sure the door to the front of the bulb in on as there is a micro-switch at the lower right that MUST be engaged.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Press the input/device button and the menu button at the same time. Green LED will blink a two digit code blink 1st digit short pause blink 2nd digit longer pause and repeat. Any number of problems can cause this same symptom.
If the red LED your refering to is the Status LED and not the Lamp LED then you have big problems. A red Status LED indicates no communication from the Format board to the DMD board (light engine). 1/2 the time caps on the format board itself the other 1/2 must send entire electronics package to Mitsubishi.
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsub replacec 52525 lamp. green timer light blinks then red steady light.
I have exactly the same problem and just had a tech leave after a $145 service visit. The cause is a problem in one of the 12 circuit boards that make up the electrical chassis (newer models only have two boards). I was given a form stating that some parts are no longer available for the first generation Mitsubishi DLPs (2004 build year). In that case, the only option is to have the entire chassis removed shipped to Georgia and refurbished. This can take up to two months and some sets have had to have this done multiple times.
I have to wait until tomorrow for news on whether the part is available or a chassis repair is the only option, and the costs. But it's looking like I have a $3000 paper weight after only 3 years (warranty was one year; the store's extended warranty was only two years). I will must likely just have to go out and buy a new set which will NOT be a Mitsubishi
Nov 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Just replaced dlp lamp
From what I remember, when you turn on the tv, use the remote and when it asks if you replaced lamp say yes.
Jul 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
Nov 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
269 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
