Question about HP OfficeJet K80 All-In-One InkJet Printer
Multiple paper feed
K80 feeds up to a dozen sheets at once
  • Anonymous Jan 09, 2008
    Deskjet F335 Feeds multiple sheets everytime. I have only used one set of carteidges so this unit is almost new. My only solution is to only load one sheet at a time.....Any ideas?
  • jones5198 Jul 08, 2008
    When printer is not qued to print, it automatically powers on and feeds all the paper in the tray until empty. I've returned to HP for check, but they couldn't find problem. I've uninstalled and reinstalled several times, but problem still not solved.
My printer keep on flashing 13.20.00 Jam inside Rear Door then open and close door. I checked for any paper jam and there is none. What can be the problem? The printer doesn't print since the attention light started flashing
Posted on Jul 02, 2008
I gave the page separator roller a light sanding with fine sandpaper to roughen the surface a bit so it could "grab" the pages more easily (one at a time!) and then used a squeeze bulb blower to blow out any dust. It worked perfectly!
Posted on Oct 09, 2007
  • 40 Answers
The paper separator pad is worn out and will need to be replaced. It's a rubber pad that rests behind the paper pickup roller and is supposed to prevent what you're experiencing. Contact your nearest authorized HP repair center.
Posted on May 29, 2007
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    PAPER WILL NOT FEED
    hi there !
    you may do the steps below:
    -Ensure the Paper Tray is Not Overfilled
    -Adjust the Printer Paper Guides
    -Locate and Remove Any Obstructions Inside the Printer and Input Tray
    -Determine if Multiple Sheets Are Fed at Once From the Paper Tray or Automatic Document Feeder (ADF).
    -Verify the Print Media Installed Is Compatible With the Printer
    -Clean the ADF Paper Feed Roller
    -Reseat the Dell Printer Power Adapter
    -Try a Different Type of Print Media
    *If all else fails
    -Replace the Dell Printer
    cheers!
    Oct 28, 2009 | Dell 962 Photo All-In-One InkJet Printer
    MP830, how to retrieve faxes in memory to my PC
    - A margin appears
    on printouts.
    2 B Paper feed
    Improper paper
    feeding:
    - Multi-feeding
    - Skewed paper
    feeding
    - Paper jam
    - Paper feeding from the
    ASF
    - Plain paper
    - Highest print speed
    (Custom setting to 5)
    - In the high temperature
    and high humidity
    environment
    - In the low temperature
    and low humidity
    environment
    - With the maximum
    amount of paper set (13
    mm)
    and high humidity
    environment, paper
    becomes wavy; in the
    low temperature and
    low humidity
    environment, paper
    curls significantly.
    When the maximum
    amount of paper is set
    in the ASF, and if the
    paper-return tab fits in a
    wave or curl of the
    paper, the tab slips and
    does not catch paper
    properly, causing paper
    feed problems.
    - Reduce the amount of
    paper set in the ASF to
    half (approx. 5 mm
    high).
    - Multiple sheets of
    paper feed at the
    same time.
    - Paper feeds at an
    angle.
    - A paper jam
    occurs.
    3 C Print results
    Skewed paper
    feeding (at the
    level of +/- 1%)
    ASF
    - Credit Card size
    Since coaxial tolerance
    between the pinch roller
    and the LF roller, which
    determines the paper
    feed alignment, is
    0.2mm, skewed paper
    feeding can occur.
    However, according to
    the field data of current
    models, the skewness
    level caused by the
    coaxial tolerance of
    0.2mm is within the
    criteria of +/- 1%, thus
    the phenomenon is left
    as is.
    - Align the paper guide to
    the paper edge tighter
    than usual.
    - Paper feeds at an
    angle.
    - A margin appears
    on printouts.
    4 A Print results
    Soiling on the
    back side of paper
    (lines or streaks
    parallel to the
    paper feed
    direction)
    - After continuous
    borderless printing of
    small sized paper (such
    as 4 x 6), when a larger
    sized paper (such as A4)
    is printed.
    - With Photo Paper Plus
    Double Sided or
    postcards, the
    phenomenon is likely to
    be noticeable and to be
    complained of by users,
    as printing is performed
    on both sides of such
    paper.
    In borderless printing,
    printing is performed to
    the size slightly larger
    than the paper size, and
    ink off the paper is
    absorbed by the platen's
    ink absorber. Absorbed
    ink may attach to the
    platen rib(s) after
    several dozen sheets are
    printed, causing soiling
    at the leading edge of
    paper or on the back
    side of paper.
    1. Perform Bottom plate
    cleaning (from the
    MP driver or via the
    operation panel) up to
    3 times*1.
    2. If soiling on the paper
    still remains after 3
    times of Bottom plate
    cleaning, wipe the
    platen rib(s) and their
    surroundings with a
    cotton swab.
    - Paper gets
    smeared.
    - The back side of
    paper gets
    smeared.
    Soiling on paper in
    automatic duplex
    printing (lines or
    streaks
    perpendicular to
    the paper feed
    direction)
    - Automatic duplex
    printing (Photo Paper
    Plus Double Sided,
    postcards, plain paper)
    On the rib(s) inside the
    sheet feed unit used for
    duplex printing, ink
    mist may accumulate,
    smearing paper.
    Temporary operational
    solution:
    Cancel automatic duplex
    printing, and manually
    print each side of paper.
    Cleaning by user:
    cleaning (from the
    3 times*1.
    - Paper gets
    smeared.
    - The back side of
    paper gets
    smeared.
    - Even after Bottom
    plate cleaning
    was performed,
    and the platen
    ribs were cleaned
    with cotton swab,
    paper gets
    smeared.
    2-10
    Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Miss feeds when print multilpe pages
    The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
    Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
    Paper feed
    Have you tried a different brand of paper?. When choosing the paper try and select one which the sheets can slide easily over each other. I had loads of problems with multiple feeds and paper jams with a cheap paper. I then changed to a heavier 90gsm all in one paper from staples and have had no more problems since.(and i just chuck the paper in straight from the packet with no fanning etc)
    Dec 15, 2008 | HP OfficeJet Pro k550 Printer
    HP paper jam
    That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
    Please remember to rate all users who assist you for free :)
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
    Printer won't feed paper
    Your paper is with excess of moisture. Try to keep the paper in a peper dryer, and do not use to leave the sheets not used in the printer, keep them in a dryer, or a dry place.
    May 02, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
    Not printing
    There is probably a paper jam in the tray feed path. The other situation is that the tray paper pick up roller has become hardened/polished, or the paper tray paper is greasy. First step, take the paper from the tray, and fan it out, so each sheet is separated from the next. try it with jut a dozen or so sheets, change the paper.
    Thoroughly check the paper feed path.
    If not working, then check/clean the rollers.
    Jan 20, 2008 | Kyocera FS-720 Laser Printer
    Automatic Paper feed
    Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
    Sep 06, 2007 | Samsung ML 1210 Laser Printer
    Slower printing speed
    Multiple sheet feeding in any printer can mean many things. Paper roller blockages and jams, wrong paper for printer, too much paper in. Make sure you check right down the back and inside the unit for anh small blocks. This can then cause errors in the printer itself. As it is now printing but slow, the paer issue could be resoved but you may now have driver errors or pc issues. Are you getting any flashing LED lights. Have you checked to see if device is showing errors or functioning correctly. Go to start menu, control panel, performance/main, system, devices, scroll down to your printer, are there any yellow exclamations? Does it say it is working ok?
    Aug 10, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
    HP OfficeJet K80 All-In-One InkJet Printer Logo
    347 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
