Question about Mitsubishi VS-60611 60" Rear Projection Television
Mitsubishi mod. vs-5072 rolls how fix?
Rolls for 5 mins then stops 3 mos ago now wont stop rolling
    Sergeant:
  • 233 Answers
Check for swollen capacitors- bad capacitors will cause the screen to roll. If the top of a capacitor even looks SLIGHTLY puffed up, replace it!
Posted on Dec 19, 2008
Rolling lines until tv warms up
Vertical output IC bad capacitors in vertical circuit 100uf 35v sometimes vertical IC needs to be resolder and that fixes problem look for poor solder joint s.
Sep 27, 2009 | Mitsubishi VS-50605 50" Rear Projection...
I have a mitsubishi modle number vs-5072 and the tv rolls all the time
Thats a common problem which is actually caused by the caps being defective on the PIP board.
Jul 12, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs-7071 rear projection tv
hey i have had the same prob on my other tv .it was about 300 to get it fixed.if you havent allready fixed it and if your not to fare away,id like to buy the screen
Jul 29, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Rear project TV problem
yes it can be fixed depending on your model number if its the VS50605 they have a kit to repair the PIP module which controls vertical sync (Rolling) or you can bypass the module to correct it but you would lose the PIP function. Let me know if you need more info.
Apr 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Rolling lines
had a few with bad (go here) capacitors
good luck
please mark the post with a fixya
Feb 06, 2008 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi vs 50607
CHeck 9 V circuit.. Change caps C2p04 & 5.. 100uf 16V & 47uf 50V..Both electrolytics....Directly behind shield on Signal PCB..
Oct 27, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
216 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
