Question about Kitchen Ranges
I have a whirlpool gas stove that all burners work fine but......when i call for the oven i only get 2 distinct clicks from the regulator and nothing else... the tech sheet on the back of the unit/gas stove......is gone...i would like a copy of that also...........no error codes are displayed on the clock i am aware it could be the clock/head unit, thermostat ...please help before the holidays
    President:
  • 2,692 Answers
Here is the website to look up you manual. You will need your model number in order to get the exact correct one..
http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=841&p_created=1161611190&p_sid=3wDbfJlj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0
Posted on Dec 19, 2008
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
My whirlpool SF265LXTS oven turns on properly, but the oven itself isn't getting hot. The gas stove top and broiler both work fine.
It sounds like you might have a clogged burner plate or manifold. You should call a certified gas repair service. This could be very dangerous, even deadly.
Dec 15, 2013 | Whirlpool SF265LXTS Kitchen Range
When dial of oven is turned on, nothing happens.
Have you checked the pilots for the oven? If the pilots are lit and it still isn't working then the problem may be the gas valve.
Mar 06, 2010 | Whirlpool SF310PEK Gas Kitchen Range
Montgomery ward gas stove. top burners work fine. oven barely gets warm
I have a whirlpool gas stove oven fire will not go off when in off position. Is the fire suppose to go off completely?
Aug 21, 2009 | GE JGRS14 Gas Single Oven
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Whirlpool gas stove
Replace the regulator on the gas line.
Jan 01, 2009 | Whirlpool SF325 Gas Kitchen Range
Gas range - top burners and oven used to work fine. Starting last week they just had low flame but now do not light. Oven set for 350 will only heat to 250. Nothing has been changed in the kitchen.
hi Brian,
you possibly have 2 separate things going on at the same time here but may be due to the same part.
since this is a gas stove, it contains something called a spark module, which lights the igniters and subsequently the burners. can you hear a clicking sound when you turn the elements on?
as for the oven, it doesn't look like it's going to temperature either. that could be due to the spark module as well.
Oct 01, 2008 | Whirlpool Kitchen Ranges
Gas oven won't light
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=53999&thid=358497
Gas oven won't light (by 2 users)
Posted by MBeird on Jan 18, 2008
Can hear the clicking of the auto starter when starting the oven, but it stops after 5 seconds and then the oven simply fills with gas. Broiler still works fine as do the stove top burners. Any thoughts?
Good question? You may have a plugged up burner and or the pipes or jets may not be adjusted correctly and it could be your igniter on the gas range because it is not igniting the spark to create the flame. You may want to have it check out with an authorized service repair tech to make sure it is safe and will function well. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
Jan 18, 2008 | Whirlpool SF367 Gas Kitchen Range
Kitchen Ranges Logo
122 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
