Question about Honeywell HE220A1019 Whole House Humidifier Humidifier
32001639-002 solenoid wiring confusion
I just recieved my replacement solenoid assembly today. My question: the wiring is not labled and wonder if there is a polarity issue when I make this slice with new solenoid? Appreciate any help. Mark
  • 69 Answers
No there is no polarity issue, either wire to either one it doesnt matter. Steve
Posted on Dec 21, 2008
Aprilaire humidifier 110
Hello, typically solenoid valves should be replaced every 7 years and they are not very difficult to replace. Just need to shut off water at saddle valve, turn off power to humidifier, and remove mounting hardware. Here is a link to store which sells the solenoid needed for your humidifier. http://www.aprilairehumidifierparts.com/product.php?p=aprilaire_4005&product=111011&category=1686
Dec 18, 2012 | Aprilaire 700 Humidifier
I have a aprilaire model 700 humidifier every year I end up replacing a solenoid. This time I replaced the solenoid but it did not fix the problem. I hear a click at the humidstat but the humidifier...
Apply power directly to the solenoid valve from the transformer and check if the solenoid opens and lets water in, If not then the solenoid is bad. If the solenoid does open up by applying power directly from transfomer then check the wiring make sure it's all tight and that the currentsensing relay/sail switch is good. Also i would check to make sure there is a strainer on the inlet of the solenoid valve and that it is clean, sometimes sediment builds up on the inside of the solenoid and can shorten the life of it.
Jan 15, 2011 | Aprilaire 700 Humidifier
Humidifier will not turn on (no fan, no water flow)
http://www.appliancefactoryparts.com/humidifiers/helpcenter/breakdowns/honeywell/honeywell-he360a1027.html
A breakdown diagram of parts etc above.
http://www.appliancefactoryparts.com/content/pdfs/110672-4.pdf
Shows you the HE360A.
To me it sounds like it is wired incorrectly, the solenoid should NOT get too hot at all. The PDF above shows wiring data.
Apr 03, 2010 | Honeywell HE360A1027 Whole House...
No water flowing to water panel but have water to the solenoid. I have a Aprilaire model 550. wondering if the solenoid is bad and how do I check it.
To test solenoid, apply 24V directly to the terminals as see if water flows through it. Alternativly, turn everything on, ensure that there is 24 volts accross the solenoid wires, if you show 24Volts and no water, solenoid is bad. To test you will need to set your meter to AC Volts.
If you have a separate black transformer supplying the 24 volts, hook that directly to the solenoid. You may also be getting the 24Volts from your furnace circuit board, if that is the case you will see two terminals usually marked HUMIDIFIER on the furnace circuit board (you will need to open your furnace usually 4 screws or so.) There is 24 volts there WHEN THE HEAT IS ON , run two new wires from those terminals to the solinoid and see if it passes water cuz that is when those terminals have voltage. Best way is with a meter though and if you have 24 volts at the solenoid AND no water, it is bad. If NO VOLTS, then could be the the humidistat or a disconnected wire somewhere in the path.
Dec 26, 2009 | Aprilaire Humidifiers
When calling for heat and humidity I have 24v at the brown wires going to my Aprilaire, but the solenoid doesn't pick. Is it the control card or solenoid? Both are mounted on the Aprilaire unit. I have a...
If you have 24 volts to the solenoid, then it's not the control card. It's either the solenoid or there's an orifice in the water line at the solenoid that sometimes stops up. To check the solenoid you need to disconnect the power to the system and disconnect the solenoid wires (the two brown wires) and ohm the solenoid. If you get a low ohm reading around 50 ohms or then the solenoid is good and you need to check the orifice. If the ohm meter doesn't move when you ohm across both leads then it's the solenoid and it needs replaced.
Nov 24, 2009 | Humidifiers
Water constantly running in honeywell humidifier
I has the same problem with my HE360 unit. The unit was in fact miswired. The head unit red wires were connected directly to the blue solenoid wires, and activated the solenoid without any signal from the humidistat. As soon as the unit is plugged inn, the water starts running without any signal to the unit. If your unit is miswired, the soleniod blue wires need to be cut and connected to the red crimp connectors.
Mar 11, 2009 | Honeywell HE220A1019 Whole House...
Water does not pass through solenoid
Thanks for your question,
first you need to determine if you have 24 volts from the transformer, if you have knowledge of electrical meters then this should be fairly easy, if not then you will need to do a little rewiring to find out if it is the solenoid, first you will need to do is shut the power off to your furnace, then get some t-stat wire, long enough to reach from the solenoid to the transformer, splice together the new wire to the wire from the solenoid, now take the other end of the wire, take the leads off the transformer (low voltage side) and hook the new leads to it, make sure the water is on, now turn the furnace back on, and if the solenoid is good the water will flow, if it doesnt, then you will need to replace the solenoid, if the solenoid does work then you know your problem lyes with the Humidistat, and you will have to replace that, but you need to determine if you have 24 volts from the transformer first, hope that helped, let us know and please rate this, thanks again ,
mr.grzz
Jan 25, 2009 | Humidifiers
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
Aprilaire 560 does not work. No clicks
I just solved a problem with mine today.  One of my low voltage power wires to the humidity control had a bad connection.  I reconnected it and I could again hear the solenoid valve clicking as I adjusted the dial control.
I found the problem with a voltmeter:  there was voltage at the power terminals on the humidity control terminal board, but there was no voltage at the solenoid valve terminals.  It was hard to push my big wires into the terminal board, but I finally secured the connection!
Dec 30, 2008 | Aprilaire 550 Humidifier
Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
813 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
