Question about Linksys Computers & Internet
Linksys voip box is kicking off my x box live
Just had digital phone put in is cisco brand and it is kicking my xbox live off also use 2.4 linksys router
    Genius:
  • 1,269 Answers
Try to change the channel of the router to a different frequency.
Posted on Dec 20, 2008
I have comcast cisco cable that is working fine but when I hook up vonage I get no internet why?
More than likely you need to enable split tunneling on vpn settings in router. If Vonage uses a vpn tunnel like other VOIP services do, then it is probably encrypting all traffic on your Internet/WAN interface. With split tunneling enabled it will only encrypt traffic to and from Vonage. I'm making a few assumptions here, but it should be worth a check.
Jul 23, 2014 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
How do I get two xbox 360s to have an open NAT on a Cisco Linksys WRT160N V2 wireless router?
you need to setup both your xboxes with a static IP address for example
192.168.1.50 xbox 1 192.168.1.51 xbox 2
on your linksys router you will need to setup port forwards for both xboxes
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
requires you to forward the following ports: 53,80,88,1863,3074
Mar 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Changing my nat type on xbox live to open its stuck on either strict or moderate
There are two things you could do from the routers end..
1) You can take the IP add of your device( X-box, PS3) and then contact the device vendor(Xbox or PS3) and ask them to give port numbers for your device. Once u get the port numbers you can either open ports on the router by logging into the router interface using your Default gateway of the router or you could put the IP add of your device in DMZ on the router. Basically this will keep the device out of the firewall of the router( Which is the main reason for this issue). 2) If the first step didnt work you could disable the firewall on the router. If both the steps didnt work you could check if your router has any firmware update or it has to be reset and re-configured and the above steps should be re-done.
Hope this helped.
Feb 17, 2011 | Linksys by Cisco Cisco Valet Plus Wireless...
Router pasword
Default user names:
  • Linksys BEFW11S4, WRT54G: admin
  • Linksys EtherFast Cable/DSL Ethernet routers: Administrator
  • Linksys Comcast routers: comcast
  • All other Linksys routers: [none]
Default passwords:
  • Linksys BEFW11S4: [none]
  • Linksys Comcast routers: 1234
  • All other Linksys routers: admin
Dec 07, 2010 | Linksys Wireless-G WRT54G Router
I have a Linksys WRT160N wireless broadband router. When I get on Xbox Live it says that I have a strict NAT type and I want an open NAT type. I have already enabled the DMZ, UPnP, and put in the proper...
try this :
1. Log into the router using 192.168.01. or 192.168.1.1
this is done using a browser window such as Internet Explorer or Firefox.
2. go to Application & Gaming
3. In the box on the right column us wan to enter the device ( example: Xbox)
4. you need to enter the start and end port next ( example: 88 and 80
5. then your protocol ( example: tcp ,UDP, or both
6.the IP address if next
7.check enable
8. then save
9. here is the site with an example page to configure your router.http://homecommunity.cisco.com/t5/Wireless-Routers/Xbox-360-NAT-issues-solved-WRT160N-v3/m-p/310658?comm_cc=HSus&comm_lang=en#M163159
Aug 21, 2010 | Linksys WRT160N Wireless Router
How do I change the NAT setting for Xbox live
7.check enable
8. then save
3.
Aug 19, 2010 | Linksys WRT160N Wireless Router
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
Button is yellow. Error msg Failed/No Response
I don't know about linksys but in Cisco you can use a TFTP Server Program, put the firmware that server, and boot up the phone. In Cisco it goest to the server and it uploads the new firmware.
Jun 18, 2009 | Linksys SPA942 IP Phone
Linksys Router Issue
My VOIP Adapter is lock I can't reach the web page
Jan 09, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Computers & Internet Logo
43 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
