Question about Harman Kardon HK695 Computer Speakers
HK695 volume issues
I have a set of Harmon Kardon HK695 speakers.  When I plug the green cord into the headphone/output jack on my laptop,  I hear a faint sound coming out of both satellite speakers, but the volume knob on the right satellite does nothing.  the volume never gets louder or softer when I press the +and - buttons.  It does change when I change the volume on the computer, but it never gets louder than a faint noise.  I have tried them on multiple computers and the same thing happens.
  • woodymr11 Dec 22, 2008
    The speakers are powered and both LED lights are lit on the satellites.   The speakers were given to me by a friend, so I have not tried them on the original computer.  Could it be an issue that I am not using them with the original computer?
  • josephrisse Feb 09, 2009
    NO SOUND on HK695 Speakers
I just spent a few hours trying to figure out how to make the volume respond by pushing the volume control buttons on the right speaker - the volume was working, but only adjustable via the software settings for volume control in windows. When I swapped the plugs in the back of the woofer unit, the buttons on the speaker worked for controlling the volume. So if you're having the same problems as me, just swap these and it might fix your problem.
Posted on May 05, 2009
  • 55 Answers
Make sure they are plugged into a power source if they are powered. If they are unpowered then your laptop may not have a powered speaker output and may not have enough power to drive the speakers.
Posted on Dec 19, 2008
How do i connect a set of Harmon Karden HK695-01 speakers to a Macbook Pro Mid 2010
HI Marc
Follow the steps below
Step 1:
Connect the green connector from the subwoofer into the headphone jack on the laptop, the black connector is not used, leave the rubber cap on the black connector to prevent static from the pin grounding on the system.
Step 2:
Plug the orange connector from the right/control satellite into the orange jack on the subwoofer.
Step 3:
Plug the brown connector from the left satellite into the brown jack on the subwoofer.
Step 4:
Plug the AC plug of the HK 965 into the wall outlet
Step 5:
Turn on the speaker set and adjust the volume accordingly.
PS: Do not Forget to adjust the Laptop volume also to minimize Distortion. Enjoy!
Jun 04, 2015 | Harmon Kardon Hk695 - 01 Audio System...
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
One side is working normally, I believe the other one may have a short of some sort in it, what would cause this?
Most probably the problem lies in the cord leading from your PC to the main speakerbox. This should be a standard DIN plugs stereo cable. Try wiggling this cable a bit and see if there are any changes, just to make sure that it is this cable. But even if there isn't any change, the probability of anything else going wrong is highly unlikely. If your PC gives normal stereo sound on headphones (eliminating the PC as a problem) then there's 99% chance that this cable feeding the audio signal is bad. You'll need to replace it with a standard DIN plugs stereo cable.
If however your PC does not give a stereo sound to headphones then double-click the speaker icon in the right lower corner of your screen, and see the output settings and output balance. The balance should be set to 50/50 so both left and right channels get the standard volume level, and that the output is set to standard stereo output.
Feb 01, 2011 | Harman Kardon HK695 Computer Speakers
I've got an HK-595 system (Subwoofer and 2 satelite speakers with controls on one speaker for Center, Bass, Volume, Treble and Surround) for my PC. Everything worked fine for quite a while, but then (it...
I am having the exact same problem with my Harmon kardon PC speakers. It is related directly to the speakers (subwoofer). If you plug head phones into the headphone jack on the satellite speaker you will not hear the noise. I am still searching for a solution, I love these speakers!
Nov 05, 2010 | Harman Kardon HK595 Computer Speakers
How do i connect the speakers to my computer?
Step 1 Connect the green connector
from the subwoofer into the green jack on the computer
(the black connector is not used)
Step 2 Plug the orange connector from the right/control satellite into the orange jack on the subwoofer.
Step 3 Plug the brown connector from the left satellite into the brown jack on the subwoofer.
Step 4 Plug the AC plug into the wall outlet.
Step 5 Turn on the speaker set and adjust the volume accordingly.
Jan 22, 2010 | Harman Kardon HK695 Computer Speakers
Need to replace ac cord on subwoofer harmon kardon hk695
bring your ac cord to electronic or computer part sales so that you can buy same specifications
Oct 19, 2009 | Harman Kardon HK695 Computer Speakers
Harman-Kardon HK695-01 Speakers Connection Quesion
According to the manual
http://tv.manualsonline.com/mdownloads/14ae515f-03bc-a2d4-8940-672bfa19f017.pdf
leave the black connector unconnected.
Hope that helps.
Oct 02, 2009 | Harman Kardon HK695 Computer Speakers
Harmon kardon hk695-01,13 - Intermittent "gargling" noise
the noise is sometimes caused by dust in the volume control.
i would suggest blowing the dust out around the volume control if there is a manual control on the unit. use a small can of compressed air.. buy it at local walmart or computer store.
Apr 28, 2009 | Harman Kardon HK695 Computer Speakers
Hearing a simple low frequency cycle up to a mid frequency over 4-5 seconds
Hello stocker
Happy Holidays
well, it is a bad capacitor on the sub, you have 2 options here, if you got warranty, go ahead and RMS your sub, or get it to repair it center to a repair.
good luck
Dec 22, 2007 | Harman Kardon HK695 Computer Speakers
Harman Kardon HK695 Computer Speakers Logo
912 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
