Question about RCA D52W19 52" Rear Projection Television
RCA hd52w59 won't turn on
My sister just gave me the tv i have a d52w19 that I had to replace CP150 cap and resolder all the Flyback Pins i have checked all these thing it wont turn on no green light comes on i did have it pluged in and touch the heatsink in the back where CP020 is and got a shock any know if should replace CP020
  • kc5cym Dec 19, 2008
    No i pulled them and check will a meter they are good also check fuses the 4 or 5 brown fuses close to flyback and the glass fuse just after the wall plug in the set
  • RCA Master
  • 5,138 Answers
Was cp 150 bad? bubbled up on top if so you have 2 more caps in same circuit that needs to be replaced they are cp111or cp120, or 114 each board has different # on location 2 caps will be 220uf 35 v, and one could be a 330uf 35v. Also when reconnecting second ribbon conector on deflection board, make sure it is in good or set will not come on
Posted on Dec 19, 2008
  • ladywinn
    ladywinn Dec 19, 2008
    Ok now check SSB board.It can shut set off.
How do I replace the CP150 on an RCA D5219 52inch rear projection?
You must know how to Solder,you will have to unsolder the capacitor and resolder in the New one
you also need to replace 3 capacitors CP150 CP114 CP120 they are all in the Same Circuit.
They are on the deflection Board which is the Bottom lefthand side and will have the FBT flyback Transfomer.
Mar 08, 2011 | RCA D52W19 52" Rear Projection Television
It turns on and you can hear it but no picture
On your deflection board, its the bottom left hand side board, CK capacitors cp150 2200uf, cp114 and cp120
220uf-330uf 35v If any of these 3 capacitors are vented or puffed up on top they are Bad replace all 3
resolder all the pinns on the FBT flyback transfomer on same board.,Make sure after replacing caps that the 2 Ribbon connector is in good or set will not come on.CK Both Ribbon connections on boards.
Mar 05, 2010 | RCA D52W19 52" Rear Projection Television
I have a RCA d52w19. when I turn it on, the LED flashes 3 times and shuts off. Basically the same problem as everyone else. However, I changed CP150, CP120 and CP114 and still have the same problem. What...
if you replace the bad cap,s cp114 cp150,cp120 and still give you flashes 3 time you do have a bad flyback 21.40 for the flyback but in the same fix you see 3 fuse by the flyback hit them with solder thay is the power supply for the conv, borad.i work for quaker tv i seen a lot of that d52w19. you mite whant to look at the power wire that go to the front buttom con,t in front of tv if thay are pich in eny way the set will not come on. but you have a bad flyback.
Dec 07, 2009 | RCA D52W19 52" Rear Projection Television
I have RCA D52W19 52 and i got problems with it
On deflection board,first board on bottom to the left CK capacitors cp150 2200uf 16v if it is puffed up on top it is bad replace 2 other caps in same circuit cp114,cp120 220uf 35v, also resolder all pinns on FBT flyback transfomer.
Nov 12, 2009 | RCA D52W19 52" Rear Projection Television
Rca model hd52w59 stays on for a few min then turns off will turn dack on after a few min some time does not do it at all
replace capacitors cp150-2200uf 16 use25v cp114 and cp120---220uf 35v resolder all pinns on FBT flyback transfomer.
Oct 02, 2009 | Televison & Video
Model d52w19 rca projection tv,will not turn on.the green power light blinks three times,but nothing happens.
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
Mar 06, 2009 | RCA D52W19 52" Rear Projection Television
Does nt turn on
I tried the flyback 259296 and that did not work. I changed the cp150 and my tv works like new. CP150 cost me $2. Flyback 259296 cost me $60 for nothing
Jan 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Stil confused
Check 3 capacitors on deflection board where the flyback is but they are located on front of board cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v Look at top of capacitor cp150 if it looks like it is bubbled on top it is bad so replace all 3.
Oct 04, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
128 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
