Question about Polk Audio RT1000I Speaker
Loud hum on subwoofer.
One of my speakers developed a loud hum on the powered subwoofer side of the speaker. When I first noticed the hum I could tap on the amp and it would go away. But after turning my hometheatre amp on it would come back. This went on for about 15 minutes. Now the hum is gone but there is no sound coming out of the sub. The fuse is ok on the amp but I don't hear the speaker "click" on like the right speaker does. The front LED is still on so I know that it is getting power. Is my amp fried? Or is it the sub speaker itself? I also tried using both the "rca" inputs and the "speaker in" inputs and nothing changed. Polk Audio wants $200 for a new replacement amp. The rest of the speaker works fine. Any help or suggestions would greatly be appreciated.
  • Anonymous Jul 21, 2008
    Same problem. Keeps humming until I disconnect the power cord. Rest of the speakers work fine at that point. Happened to one speaker then the other. Left unplugged for a while. Problem went away then returned.
    Genius:
  • 1,074 Answers
Try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Posted on Mar 30, 2007
SOURCE:
Velodyne ct100 loud humming +speaker drown backwards.Can I fix at home
The loud humming could be caused by a cable on the input that is not grounded. It could also be caused by some sort of power supply failure.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Feb 10, 2016 | Velodyne Audio Players & Recorders
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Loud humming sound from subwoofer PSW111 (specially(noticeable once AV receiver is off).
Check the connections from your reciever to your subwoofer. It sounds like they may be a little loose.
May 15, 2011 | Polk Audio PSW111 Speaker
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
Older Harman Kardon computer speakers have loud hum
The hum (50 or 60 Hz) is caused by the AC power getting into the entry point of the amplifier. Either the filtering capacitors from the powersource of the speakers have dried up - replace them - or there is a short in the cables.
There is another possibility: if you have kicked the subwoofer  box its transformer might have slipped from its fixings and now is touching the subwoofer speaker frame.
The only way to find which is to open the cases.
Nov 28, 2009 | Harman Kardon HK695 Computer Speakers
Most probably it's an internal problem with their power supply (a capacitor with broken soldering).
It can be quite easily repaired by a person knowing which side of a soldering iron to grip ;) If you have a friend that's familiar with electronics, you can ask to take a look. If you don't, the repair shop will most probably want a flat charge, which will not be feasible.
Nov 28, 2009 | Audio Players & Recorders
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
just try leaving it unplugged for a while thats what i did and it fixed it
Sep 21, 2008 | KLH PSW8100-8 Subwoofer
GMAC 5100 Speakers
I think that the internal power supply is at fault the rrpair would be to repair it
Aug 12, 2007 | Gateway GMAX 5100 Computer Speakers
Polk Audio RT1000I Speaker Logo
981 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
SANDIP MISTRY
SANDIP MISTRY
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
