Question about Acer Aspire 5100 Notebook
Motherboard fried for no reason and suddenly
I want to replace the motherboard but not with another original that might go again. I hear these boards die regularly. Is there another motherboard that will last that will fit in? Possibly one like an extensa? I don't want to replace it only to replace it again in another year or two.
Thanks,
Paul
  • pbrods323 Dec 19, 2008
    I just replaced it with an ACER Extensa 5630Z. I've already stripped down my 5100 and took the motherboard out. I'm looking to replace it to give to my wife. Right now my wife has a frankenstein laptop that I built out of pieces of different laptops. It works but is ugly and very old. I'd like to buy a motherboard for $100-$150 and give it to her to replace her junk.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
I understand your pain. Acer has a extensive case-history of motherboards that die or quit for no reason. Do a search and you will find forums full of complaints where the machine just quit for no reason and did not start ever again.
I repair laptops for a living and see dead Acers in here all the time. Replacing the motherboard of a dead laptop is not easy. If you know how to work on computers, make sure you have a Service Manual for that make and model to make sure you can reassemble the computer. I do NOT recommend this.
I also do not recommend replacing the motherbaord at all. Firstly, only an ACER mainboard for that particular model will work - and secondly if you have to pay for another mainboard plus installation, the cost of labor and parts will likely exceed the value of the machine - which even if repaired with a new mainboard - could conk out on you all over again.
My advice - consider it totaled, invest your money in a newer model, and think twice before you buy Acer again.
Posted on Dec 19, 2008
GE side by side fridge HSS25IFMDWW burnt pin on relay on main board and compressor not running. Tested compressor and it runs okay. What would cause the burnt pin?
Most times the motherboard is the problem that causes the solder to melt from a defective relay. You will need to inspect the compressor start relay and capacitor to insure that they did not cause the relay on the board to overheat. Also check that you have 12 volts dc going to the evaporator and condenser fans while running because if for some reason the fans are defective and you change the motherboard while one of the fan motors are defective your new motherboard again can be damaged. Here is a link to a=> Artica/Profile Service Manual
Here is a motherboard test photo=> Artica Profile Tech Sheet I will be glad to help answer any questions you may have Thanks Sea Breeze
Aug 28, 2012 | GE Refrigerators
Powerbook G4 12" no video
Try this courtesy of your manufacturer
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the computer.
If that doesnt work lemme know
Feb 03, 2010 | Apple PowerBook G4 Mac Notebook
After inserting device in USB port, system went down and won't boot back up. Someone told me that it was probably the motherboard. Is there any possible solution other that replacing the motherboard?
I have seen it so many times where USB fries mother boards for no reason. Well one reason is plugging it in the wrong way but if it don't boot up most likely you have to replace the mother board.
Jan 12, 2010 | Office Equipment & Supplies
Original motherboard
Hi, When i change motherboard that got fried I change also the Temperture sensor Number: WR55X10087
it is under the cover on the right side
Jan 07, 2010 | GE PTS25LHP Top Freezer Refrigerator
Sound problem
mmm, umbuntu is a problem, go to the website of the mother board and get new drivers, if it doesnt work yust install linux again, after that if it still doestn work get windows
Oct 04, 2009 | Intel Motherboard
Black screen,then test screen.Did the mobo or vid card fry?
if you fried a psu, it was probably caused by a motherboard fault.
You could try removing the geforce card, and try plugging the monitor into the onboard graphics port if it has One. These boards also suffer from bios chip problems, so a replacement bios chip may be another suggestion. failing any of this the motherboard is faulty and should be replaced.
Mike @ compurepair.
Jun 11, 2009 | ASUS M2N32-SLI Premium Vista Edition...
Ddr ram
welcome to fixya
if something burnt out most of the time the mother board is gone (junk) if nothing eles try to remove the new memory and try to reboot if still nothing happens then you fried the motherboard
sorrry to hear this
have a good day other wise :)
Jul 31, 2008 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Mother board dead
Hello how are you. Please give me ome detailed information the make and model of the computer. i will help you with this. Easy. This is what I do for a living.
Thank you hope to here from you
Feb 10, 2008 | Intel Motherboard
Motherboard keeps frying. Original and replacement have both gone bad. Any help appreciated.
Have you checked to make sure your power supply hasnt got a fault. In the event of a motherboard fry up, the power supply should be checked and if in doubt change.
Dec 02, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Acer Aspire 5100 Notebook Logo
119 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
