Question about Air Hogs Glow In Dark Havoc Stinger Rc Helicopter
Main rotor does not spin on brand new Air Hogs Havoc Stinger heli
We have opened the package and charged the batteries to full, but the main rotor will not spin. The rear rotor spins just fine. Any ideas or help on this?
  • 5 more comments
  • vulkenboy Dec 25, 2008
    i have the same problem on a brand new one as well
  • Anonymous Dec 26, 2008
    I have the same product, but the main rotors stopped working after about 2 weeks.
  • r23d1 Dec 26, 2008
    Went to air hogs/spinmaster website and neither are helpfull. Called helpline and waited over 30 minutes before hanging up.
  • stumped119 Dec 28, 2008
    I have the same problem, but it started on the second charge up. For the first charge everything worked perfectly. Charged up again (according to all instructions) and then main rotor no longer spun. Tail rotor still works.
  • Anonymous Dec 29, 2008
    my air hogs stinger's main rotor snapped in half. How do I fix that?
  • guitarded13 Dec 29, 2008
    got mine brand new for christmas, no instructions in box. don't know what the "ABC" is on the charge button. neither rotors worked right out of the box.
  • Anonymous Mar 26, 2014
    the heli just won't lift off....it keeps spinning its blade with full power but is not willing to fly.....can someone please suggest me a solution
After having the same problem I got through on the phone to spinmaster this morning (it only took about five minutes). They said the problem is likely that either the gears have slipped or the shaft has disconnected from the gears and motor. They said the problem cannot be fixed by the user and the solution is to get a warranty replacement.
After opening a warrant case and giving me a case number (important!), the customer service rep asked me to email a copy of my receipt along with a picture of the helicopter with the main rotor cut off (to show that we weren't using it any longer) to their warranty department along with the case number and a description of the problem. She said they would ship out a replacement within two to six weeks. Hopefully this works. Good luck.
Posted on Dec 28, 2008
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
i got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Mar 22, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
Why won't my havoc heli's main rotor spin
i would try to look for hair stuck in the main rotor
Mar 09, 2010 | Air Hogs Havoc Heli Helicopters
Hi, the main rotor of my havoc helicopter is spinning in an unbalanced way and causing a high level of vibration making flight impossible
Look on the underside of the rotor. You may be missing one of the small metal weights that balance the rotors.
Jan 08, 2010 | Air Hogs Havoc Heli Helicopters
How do you remove and replace the main rotor on the Havoc Stinger? I wasn't able to find a replacement blade for this specific model. Will the replacement blade for the Havoc heli work. Mine is clear not...
I just experience breaking my 1st main rotor and replaced it.
What you need are a pair of needle nose pliers and a hair dryer.
Put the hair dryer on "HOT" and blow on the rotor plastic shaft for
about 1 minute. Then take the needle nose pliers, lightly clamp
them on the plastic shaft and lift. It should slide off the metal shaft.
Next I took the hair dryer again and heated the replacement rotor
shaft for about 1 minute and pushed in on the metal shaft with my fingers.
Hope this helps.
Dec 25, 2009 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Problem with the back rotor.
make sure there is no debris such as hair thread or string caught in the back rotor. this will cause it to lock up. Remove it and try fiddling with the trimmer button to help it stop spinning the helicopter
Jan 07, 2009 | Air Hogs Havoc Heli Helicopters
My Havoc Heli got wet
Most likely you short circuited something and now it can't be fixed. I would send it back to the company to be replaced.
Jan 01, 2009 | Air Hogs Havoc Heli Helicopters
Air Hogs Glow In Dark Havoc Stinger Rc  Helicopter Logo
471 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
