Question about Sony ICD-B26 Handheld Digital Voice Recorder
My recorder appears to have died....
Hi, my voice recorder started beeping due to low battery power (i think)... this has happened before and i changed bateries and no probs, however this time i didnt change batteries and after an hour or so the beeping stopped and the screen went blank. since then i have tried installing several new sets of batteries and nothing, nada, zip.... no signs of life whatsoever... would appreciate any help to get it going again... thanks.
Gryfox
  • 216 Answers
SOURCE: no picture on viewfinder or LCD
This is a common CCD defect in numerous Sony and other digital cameras. It will be covered free of charge by Sony even if the equipment is out of warranty. Check this site: http://www.imaging-resource.com/badccds.html and use the link there to get your free repair!
Posted on Jun 18, 2006
sonyspares
  • 89 Answers
SOURCE: LCD DISPLAY BLANK
The LCd connecting Flexible strip might be faulty. If you can view the picture in dark way,then the back light can be the faluty part. If they are all OK, then replace the LCD. The connecting strip is failing fast as per our experience and this costs US$ 21.00 and it is available with us.
Posted on Dec 30, 2006
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
joebert
  • 29 Answers
SOURCE: Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Posted on Feb 06, 2008
  • 42 Answers
SOURCE: ps3 frozen or blank screen
I have seen this problem a lot lately. Make sure you run a system update and update to the latest firmware which is currently 2.60 this should resolve your issue.
Posted on Feb 12, 2009
How do I turn it on
There is two red lights, one means you are recording and the other is low batt. which one you are talking about?
If it is Low batt light,there is dirty or bad contacts at battery compartemt. clean it with alcohol and a piece of cotton.
The other light is you are recording.
also you are in VOX mode, disconect.
VOX means voice operated without hands.
Sep 22, 2014 | RCA RP5010 Digital Voice Recorder
Replace battery
Have you considered replacing the baterry to see what happens?
Feb 10, 2014 | RCA RP5030 Digital Voice Recorder
System check
I've been having the same problem recently. It seems it might be low battery power. When I turned my recorder on, the battery was showing three bars, then down to two, but one would think it should still function with two bars.
However, before I went to buy a new recorder I decided to put a new battery in. So far it has not messed up again with the new battery. I'm pleased because I've used the heck out of my recorder and LOVE it...don't want to have to buy a new one.
May 04, 2010 | Olympus WS-311M Digital Voice Recorder
Olympus DW90 Digital Voice Recorder - Display Shows CHK and beeps
Make sure the recorder is out of the HOLD position. The HOLD switch is like the on/off button to the device. If you move it out of HOLD the device should come on and you should be able to start recording on it.
Jan 22, 2009 | Olympus DW-90 Digital Voice Recorder
Recording Time
I have one of these recorders, I actually have 4 or 5, since discontinued I believe, and one is stuck at 43 min remaining.
I think that problems start when you remove the battery while
the recorder is / was in the process of recording (or in play mode) I now press stop while recording before opening the battery case to switch a battery
Mar 04, 2008 | Olympus WS-100 Digital Voice Recorder
Camera wont turn on
The camera may in fact be hung in voice recording mode, or may in fact have a low voltage error or internal failure. Suggest that you follow this routine. 1 remove batteries and press the on button, nothing should happen. Allow camera to sit for five minutes. 2 remove memory card if one is installed into camera. 3 install two fresh batteries in camera and attempt to power it on. 4. once on set the time and date. attempt to take a photo. then cycle the camera off. Once again power it on and see if the settings remain intact. If it is working then power off and insert the memory card and test again. I have found that allowing the camera batteries to run low and die in the camera cause a series of problems like the one that you have. Always use rechargable batteries of the Nickel metal hydride construction in this camera. This is the only known reliable power source for this camera. Note: camera instructions for this model can not be found on the samsungusa site and you will have to go to http://www.samsungcamera.com to find instructions for this older model.
Jan 27, 2008 | Samsung Digimax D53 Digital Camera
Voice recording issue
I beleive this is an indicator to the person on the other end to let them know they are being recorded because legaly they have to consent to being recorded and they have to be told that they are being recorded.
for this reason I don't think you can stop this beep
Nov 06, 2007 | Motorola Mobility RAZR V3
Sony ICD-B26 Handheld Digital Voice Recorder Logo
43 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
