Question about Maytag MDE7600AY Electric Dryer
While my dryer is running it makes intermittent squeaks.
Is this most likely a belt? rollers? It's a Maytag Atlantis that is only about 4 years old.
  • 85 Answers
Most of the time your rollers and belt are fine 1st thing to check would be the idler pully which keeps the tension on the belt so the tub spins
Posted on Dec 19, 2008
My dryer is squeaking loudly when I first put clothes in it, quiets down after 10 minutes or so. What do I need to do to fix it? Do I need a new belt of some kind. Can't find manual:(
The dryer needs to be dis-assembled and the drum removed.
Then remove and clean the drum support roller wheels and shafts.
Inspect the front drum glides for wear.
Also remove and clean the tension roller shaft wear the belt rides at the motor.
Inspect the drum felt seal for tear and wear.
Feb 20, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
My maytag atlantis dryer is making a loud squeaking noise. sounds like metal on metal. possibly a bad bearing? any ideas...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Jan 02, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE 7400AYW is squeaking bad. Not sure, could it be a rear drum bearing grinding on the roller
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 28, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Squeaking Noise coming from Dryer
Could be the roller next to the heating element. Heat tends to cause more wear in it. Use some HVAC oil to lube those noisy rollers. 6b5c930.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 02, 2010 | Maytag PYE2300AY Electric Dryer
Dryer makes squeeking sound when running
you need to replace the rollers an idler an belt,,,this will stop your noises...call if need help...
May 10, 2010 | Dryers
My whirlpool (ggw9250pw3) gas dryer loud squeak
THIS SOUNDS LIKE AN IDLER PULLEY THAT KEEPS THE TENSION ON THE BELT. SECOND CHOICE WOULD BE DRUM ROLLERS.
Apr 24, 2010 | Whirlpool GGW9250PL Gas Dryer
Had a service call 7 months ago on 16 year old Maytag Stack w/d to lubricate drum roller that was squeaking. Squeak has returned. Any pointers on lubricating it myself, or is it worth replacing the drum...
Lubricating the bearings is usually only a temporary "quike fix".
Replace the bearings,and lubricate the bearing shafts with a lithium grease.
Mar 04, 2010 | Maytag Dryers
I have a Maytag Atlantis gas dryer. It makes a squealing sound when it's on. The longer the dryer is on, the more intermittent the sound is. What could the problem be, belt or bearings?
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Sep 13, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
My series 80 dryer squeaks
do not lubricate anything in a dryer you will damage .locate the the squeek if it is coming from the rear of the unit most likly need to replace the drum support or wheels if its intermittant and has a squeek squeeek noise that either gets worse or goes away when the dryer heats up the tensioner pully or the moter berrings are bad
Aug 10, 2009 | Dryers
Maytag Dryer, 25 year old dryer has a loud squeak
Hello.
The squeaking is coming from the rollers that the drum rides on. If you take the model number to a local appliance service store they will have the parts and be able to direct you on replacing them.
Jul 20, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
208 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
