Question about HP Office Equipment & Supplies
I don't know how to put in the ink cartridges?
All in one fax , printer, scanner,  I don't know how to load the in cartridges.
    President:
  • 2,692 Answers
Do you have the manual for your printer? If not you may download it from the HP website.
Posted on Dec 19, 2008
Replaced Cyan ink and now it will not recognize. Brand new cartidge
Did you use HP ink or generic? Generic inks will only be recognized if they have the chip that talks to the printer. That is not to say they won't work - you just will not know the level. If you did use HP you have to make sure you have removed the taped portions, and that it "clicked" when you put it in the cartridge. Also - double check you really put in Cyan, I have put in the wrong color in a slot and it will not recognize the cartridge - boy did I feel really silly that day!
Dec 04, 2015 | HP Officejet Pro 8600 Plus e-All-in-One -...
Do I need black cartridge to fax
Generally you don't need ink to fax. Like sending a email that the receiver needs to print. However some printers will lock up and nag about cartridge empty before they let you move a inch
Sep 12, 2012 | Lexmark Interpret S405 - multifunction ...
Where can i put lexmark ink?i can't see the place where should i put the new ink for lexkmark x2650
Make sure the Lexmark X2650 printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will move to the center automatically for the loading position.
Press the down the carrier levers to open and remove the used cartridges. Load the new cartridges and close the cover. Close the scanner unit.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Nov 06, 2010 | Lexmark X2650 All-In-One InkJet Printer
Black ink cartridge
you should be able to disable black ink printing by going to the printer preferences selection through your Windows OS printer & faxes function.
Alternatively, if you have loaded the printer monitoring CD that came with your printer then the ink status function should prompt you to disable the black cartridge if it detected it has run out.
May 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
I have a Lexmart X4270 Printer Copier. I replaced the print cartridge but it still doesn't print.
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Oct 27, 2009 | Lexmark X4270 All-in-One Multifunction...
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Reinstalling ink
I put a new magenta cartridge in the printer. It says to open the scanner cover, then reinstall ink cartridge. when i open the scanner cover nothing happens and i dont know how to install the ink.
Oct 03, 2008 | Brother DCP 115C All-In-One InkJet Printer
Unable to load scanner driver for epson rx 640
Sir,
Check this link for your driver software...
http://www.internet-ink.co.uk/epson-rx640-printer-ink-cartridge-reviews/epson-rx640-printer-ink-cartridge-reviews.htm
http://www.linuxprinting.org/show_printer.cgi?recnum=Epson-Stylus_Photo_RX640
Thanks
Good Luck
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Don’t forget to rate the solution
Jun 15, 2008 | Computers & Internet
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
