Question about JVC HD-61Z886 61" Rear Projection HDTV
Hdm ps3 i have JVC HD-61Z886 61 in and im trying to conect it to my ps3 thru and hdmi cable but im not geting no singnal on the digital output channel
Have you went into the video setup on your ps3 and changed the resolution to 1080p?
Posted on Jun 06, 2009
I have a JVC HD-70FH97 hooked to my digital box, via HDMI cable, and connected to the TV HDMI input 1. I cant get my surround system to work - any ideas what im doing wrong?
Check your HDMI audio settings. It may be trying to send a signal that is incorrect. How is the wiring setup? cable box to stereo, then to Tv?
Sep 21, 2016 | JVC HD-70FH97 70 in. HDTV Television
Why will my ps3 not workwhen conected via multi-av cable to the RCA jacks?it does work conected to a hd tv via hdmi
When you use an HDMI cable with your PS3, the system is outputting the signal in a digital format. You need to tell it to switch back to displaying in an analog format to use the RCA jacks, otherwise it won't work. To do this, turn off your PS3. Then, once it's off, press and hold down the power button on the system. After a few seconds, it will beep and reset the output signal back to analog. Just make sure only your RCA cables are plugged in when you do this. Hope this helps!
Aug 26, 2011 | Sony Playstation 3 (PS3) Console
HDMI broken on JVC HD-56G786 TV
have you ever went thru your hdmi setup procedure that jvc recommends?
Sep 07, 2009 | JVC HD-56G786 56" Rear Projection HDTV
Ps3 starts and the green light is on but no image omes up on my
Try connecting the PS3 to your TV with a scart cable first and go to the appropriate channel. The problem you are facing is probably because the default output is not HD. So you must change it to HD you can do this by going on your PS3 display settings, whilst your operating on standard definition, AV1 or something like that. When the you are on display settings plug the HD cable in the PS3 while still being on AV1 and then plug the cable in, this may prompt a message saying that a HDMI device has been detected and you can change to HD, if this message appears switch to the HDMI output and then select yes and automatic on the PS3 for optimal settings in HD. If the message does not appear then select the HD output yourself after plugging the HDMI cable in and then change to the channel and do the same.
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Ps3 start up promlem
so if you have ever had your ps3 connected to HDMI (HD cable) before, and your forgot to change it back to the normal cords that came with the game (yellow, white, and red) then you will have to connect it back up to the HDMI and go to the Display Settings and change your video output to the one that came with the ps3 (which looks like just one yellow in the settings.) then after you do that then the screen might go black if your HDMI and regular cable are on a deffirent channels, so you turn to the channel that the yellow white and red cable needs to be to, then it will show the screen and ask you if you want to leave it at this setting with this video output/cable then you say yes then your good to go.
Oct 09, 2008 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
JVC HD-61Z886 61" Rear Projection HDTV Logo
255 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
