Question about Compaq Presario 1510 (White) 15 in.CRT Conventional Monitor
Have lost ability to control brightness.
We have had this monitor for years but just last week the brightness has become all screwed up. Even when booting so it should supposedly be a black creen with some DOS text our's is displaying a bright grey. overall it is very difficult to use, but before I dump it I thought there might be a fix available. thanks in advance.
  • Compaq Master
  • 3,402 Answers
Lost,
wow a CRT that even glows at all , and you wonder why its dem
the electron gun cathodes get weaker every day of its life.
all CRTs do that, not one or even TVs using CRT
the red gun always goes dim first so we crank it up in the OSD.
if it fails on all PCs, the monitor is bad, a 5 min test. and bingo
then if the monitor is known bad then what.
the OSD screen ever seen that, and the front panel key marked MENU/?
go there and play with brightness, and even the electron gun tuning, the page for that is RGB, Red Green blue.
adjust them so white looks OK.
but if all are dim, that is normal for old CRT,
we only get like 3 folks a year stuck in 1990s... or older.
the labor to fix it is 3 times a new LCD LED display.
land fill time. like the other billion made, and scrapped
Posted on Nov 20, 2017
SOURCE: Horizontal Bright White Line in Middle of Screen.... and thats it.
I am having a similar issue with my NEC multisync FP912SB monitor. In my case the problem is intermittent, the line remains at the same level of brightness, and the osd, when activated, is compressed in that horizontal line as well. The problem is occurring more and more frequently. Banging on the sides of the monitor sometimes brings the picture back temporarily. I came across this. http://en.allexperts.com/q/Monitor-Problems-2115/Thin-horizontal-line-monitor.htm
It states that the problem is called vertical collapse and is caused by the failure of a couple of I.C.s in the monitor.
Hope that helps.
Posted on Nov 13, 2007
Benimur
  • 6966 Answers
SOURCE: Brightness
All CRT type monitors have an FBT that supplies the high voltage to the tube. Additionally, it also supplies the G2 voltage that is responsible for the screen voltage. Often the adjustment for the Screen/G2 requires a bit of tweaking after some time of usage. Incidentally, there is another adjustment in the same area for the Focus control. Of course, adjustment would have to be done on a "live set" and on the high voltage section, extreme caution must be exercised when performing this operation.
In some extreme cases, it could be a cold solder or loose connection in the squarish PCB at the very rear of the tube. Alternately, it is also possible for a capacitor that is nearing end of life (dried up).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 21, 2008
chinna_1977
  • 65 Answers
SOURCE: COMPAQ 7500 monitor, MenuBar/Brightness Bar, Keys not working
replace Menu buttons (Microswitches) and check 5v path
check dry points.
Posted on Oct 15, 2008
pravinbhavsa
  • 348 Answers
SOURCE: monitor is control locked
you did not given details of model, company complet discreption of problem ok no problem you press the four keys on the monitor for five seconds simultaneusly or till it will show the massage "keys unlocked" then release
Posted on Nov 23, 2008
  • 77 Answers
SOURCE: The brightness adjustment bar appears on the screen all the time
Press the menu button on monitor select the brightness press the menuside button increases or decreases.after select exit oress the exit button on monitor.
Posted on Jul 13, 2009
Dim monitor issu. I want it bright always.
it could be age-related but there is also a power setting in the OS. Alternately you can check also the monitor OSD and see if there is a setting for adaptive brightness enabled
Feb 26, 2016 | Compaq TFT5015 15" LCD Monitor
Brightness and contrast increases suddenly
Check following:
1- VGA chord; is it loose or faulty?
2- Power Supply section not regulating perfectly.
3- Supply line from SMPS/Regulator power supply to EHT.
4- Brightness lines and controls (Resitance may be dry soldered or burnt)
5-Pin connection on rounded board of CRT neck may be loosed, Check it if loose than fit properly.
6- Adjust the precet for accelearting and focusing anode externaly fixed with EHT if inbuilt in EHT than only solution is to replace the EHT only.
Feb 15, 2010 | LG Computers & Internet
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Will not display a picture
It would appear that some component has given out the ghost. The earlier symptoms were giving you warning that something was failing. If the monitor fails to display anything, even after increasing the brightness to the max, it's probable that it needs servicing, or replacing it altogether.
You don't specify how old your monitor is, nor whether it's a CRT or LCD, but in both cases, they're built to last several years, except for when they come with faulty components from manufacturing.
Apr 12, 2009 | Computers & Internet
Sudden color distortion
this can happen if there is a poor connection of the VGA cable - tighten the screws on both ends, just in case one is loose
Dec 28, 2008 | KDS K22mdwb LCD Monitor
LG Studioworks 700E
It sounds like one of the capacitators inside the monitor is malfunctioning, these little things store a certain amount of necessary power and then discharge it when it is needed.  If it is malfunctioning, it could explain why it takes so long to charge, and why when you hit it, it suddenly comes on.
Jan 09, 2008 | Computers & Internet
The Contrast screen pops on all the time
It looks like your UP button contact is demaged.
SOLUTION is to insert a piece from your business card mostly above the button to adjust it down or up. It works fine.
Dec 09, 2007 | ViewSonic VX910 19" LCD Monitor
Compaq Presario 1510 (White) 15 in.CRT Conventional Monitor Logo
47 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
