I need a manuals
SOURCE: what size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
SOURCE: I have an American Legacy Amplifier series II
usualy a 30 amp fuse because they can hold alot more power than a 20
SOURCE: legacy audio LA590 car audio amp protecet mode
Is that on all the time or are you saying the light is on? If that light is always on that just means it's protecting your amp. If it's off and not playing bass then your in trouble
SOURCE: CAN THE AMERICAN LEGACY SERIES
yes, should be fine in series or parallel. it will run hotter under lower ohms but crank out more volume!
SOURCE: how to fix a Legacy LA490 amplifier
sounds like output transistors proffesional repair time sorry
