Question about Intel Motherboard
Laptop pointer floats across screan out of control
Whether I am using my laptop pointer or touchpad my pointer floats across screan out of control. It floats off screen and I have some control with the point. But when i take my finger off the pointer it floats away
Is this a cXXX series Dell laptop? If so, this is a common problem with the touchpad and integrated wrist rest and bezel. You can disable the touchpad within the synaptics control panel if you use it. If you just use the windows driver, you may not be able to disable this. I will sometimes just disable both the touchpad and touchpoint and go with an external USB just so it does not wander.
Posted on Dec 19, 2008
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
The cursor jumps around on my ASUS K501J notebook.
Step 1
Step 2
2. Select the "
Apply."
4. Pick the "
Step 3
Oct 08, 2012 | ASUS K50IJ Notebook
Cannot use keyboard pointer controls
Go to Acer's website and find the support link. There will be somewhere on there to download drivers for your laptop (you'll need a serial number). Find the one for your touchpad/pointer and install it.
Jun 21, 2012 | Acer Aspire 5050 5430 Laptop
How do I double right click if I don't use a mouse, I use a touch pad
Notice how the touchpad is laid out. Normally there is the big square area that you slide your finger across to control the mouse pointer. Then either at the top or at the bottom of the touchpad there will be two separated squares that you can click on. They work just like a mouse. the one on the left is a left click, the one on the right is a right click.
Apr 03, 2012 | Acer Aspire 5720 6497 Laptop
I have a HP pavillion DV6-1250us Windows vista home premium and i cannot get my mouse to scroll up or down? how do i fix this?
To move the pointer, slide your finger across the TouchPad surface in the direction you want the pointer to go. Use the TouchPad buttons like the corresponding buttons on an external mouse. To scroll up and down using the TouchPad vertical scroll zone (right edge of the touchpad), slide your finger up or down over the lines.
NOTE: If you are using the TouchPad to move the pointer, you must lift your finger off the TouchPad
before moving it to the scroll zone.
Mar 03, 2011 | Computers & Internet
Floating pointer
I had the same problem once. Do a system restore. Try that.
May 26, 2009 | Computers & Internet
Touchpad Sensitivity
Click on the start menu and select "Control Panel". Once in the control panel, select "Hardware and Sound". Once in the hardware and sound menu, click on "Mouse". Once the mouse menu comes up, there should be a tab labeled "Dell Touchpad". Click on that tab and then click on the large touchpad icon to take you to the touchpad options. Once in the touchpad options menu, click on "Device Select". Once you click on deivce select you should see the option to "enable" or "disable" the touchpad.
Mar 28, 2009 | Dell Inspiron 6400 Notebook
Cursor(pointer) cannot be moved by using touchpad but possibe wit
This happens to me also. Check whether the touchpad is enabled (laptops do have an option of enabling / disabling the touchpad). Secondly, you can try reinstalling the touchpad driver. Uninstall and then re-install the driver. Re-boot the system. Try using the touchpad.
Hope this helps., if so, rate me.. thanks - billa
Dec 20, 2008 | Lenovo Thinkpad R61i Notebook PC
Laptop touchpad is left-clicking when it is touched.
hi,
Please reduce the touchpad sensitivity. that shld take care of teh issue.
inu
Dec 09, 2008 | Gateway MT3705 Notebook
Intel Motherboard Logo
102 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
