Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Jenn-air w-136 won't heat.
Hi. The unit has not had a tremendous amout of use. I have ran it through the self clean mode a couple times. No problems. I recently ran it through the self cleaning mode for 3 1/2 hrs. because it was pretty dirty. Since doing so, the unit will not heat. It is actually the top unit on a double wall set and the bottom unit works fine. The appropriate fans come on when the selector is set, but the heating elements are not getting current. I feel as though the excess dirt in the oven may have contaminated a circuit or switch? I have put the unit in clean mode with the door open (you just have to hold the catch) and no heat. I was just going to start tearing it down when I thought about the internet. I was hoping to find a wiring diagram to see if there was an additional fuse or diode that may be fried. Any help would be appreciated. Thanks. Tom.
SOURCE: Problems with Jenn-Air Electric Double-Wall Oven
Try changing the clock assembly --
http://www.partselect.com/ModelFrames.aspx?ModelID=221346&ModelNum=WW30430P&mfgModelNum=&ManufactureID=1&Selected=51238&Position=1&mfg=Maytag&Type=&Mark=1
here is a link to the diagram.
PS120923
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
Posted on Feb 17, 2008
rickzilla
  • 706 Answers
SOURCE: lower electric wall oven won't heat up
It is highly likely that your heating element is open so I would ( with power removed) verify the integrity of the element by detaching it and making sure it is not elecltrically OPEN, It is nothing more than a big power resistor that when current is flowing,..gets hot but if it becomes open.. you will not have any curent flow thru it ( or heat generated from it). That would be the first place I would look.. It could also be the control that feeds it..
A few ideas to check..
Regards,
Rick
Posted on Feb 16, 2009
  • 189 Answers
SOURCE: Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Posted on Mar 23, 2010
jumptrout51
  • 3361 Answers
SOURCE: Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Posted on Jul 16, 2010
mc1bean
  • 3053 Answers
SOURCE: Jenn-Air 27 in. Electric wall
Hello, lebyar
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Just need to know how to self clean
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 18, 2011 | Jenn-Air JJW8230D Electric Double Oven
The door won't lock when I put it in the self cleaning mode.
heatman101
Jan 16, 2011 | Jenn-Air Ovens
I cannot get my Jenn Air oven to self clean. The fan comes on but does not clean--only cool air.
heatman101
Dec 11, 2010 | Ovens
Cannot get the oven cleaning feature to come on--fan only comes on.
heatman101
Dec 11, 2010 | Jenn-Air Electric Single Oven
How do you set the oven to self clean. Lost instruction book
heatman101
Dec 11, 2010 | Jenn-Air JJW8230D Electric Double Oven
Can't remember how to set for cleaning the oven
heatman101
Dec 10, 2010 | Jenn-Air JJW8530C Expressions Collection...
HOW TO START THE OVEN CLEANING MODE?
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
May 12, 2010 | Jenn-Air JJW8530C Expressions Collection...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
67 people viewed this question
Top Jenn-Air Ovens Experts
Craig Butler
Craig Butler
Sal De
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
