Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I cant disconnect my shield w/ power supplyboard from tv
I am trying to fix my wd 52525 and i have my tv taken apart all the way down to the power supply board... there are orange and brown wires that seem to be an obstruction plus a screw holding the shield in place that i cant get to... is there an easy way to get to power supply board or remove the shield am i making it harder than it is?
  • Natekc135 Dec 20, 2008
    I see no easy way at all to get into the board
  • Josh Crager
    Josh Crager May 11, 2010
    take a closer look, the shields all come off easily.
  • 41 Answers
There is nothing easy about this repair, I am a tech and allow 2-3 hours even now after doing many times.
Start with the sheild on the right, closest to the light engine. you will need to loosen the input jack board to get this sheild off.
2nd remove the middle shield, you will need to unplug the fan attached to it. Now you can remove the one over the power supply.
Posted on Dec 21, 2008
WD-52525 will not turn on, Flashing Red light.
if that is a dlp tv . not shure just by model. but if it is then they do have a lot of problems with vented filtor capacitors on power supply and other boards. magor work unless you replace chassis. but the very first thing to try is lamp and make shure cooling fans and vents are clean. J.D.W.
Jun 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525 flashing green light reset does ot fix. have to unplug for a few seconds to fix. Is this a conputer probem inthe TV?
Ur DM power supply board have problems.U know how to solders?Capacitors bulb up or pop open.Replaced this capacitors will fix ur Flashing power.Tries website Tv repair World.com to buy these capacitors to replaced.
Apr 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Hi, I have a Mitsubishi WD-52525, and have the Green Light of Death. I plan on replacing the capacitors, and have the Power Chassis out of the TV. However, I am having issues extracting the DM module...
The DM is the second board in the chassis from the right side looking in the rear. The first board is the FMT. The second is the DM, third is the Signal and the one which is sideway across the front is the Power board. The Chassis metal shields have to be removed to access the boards.
Dec 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green timer light on mitsubishi wd 52525
disconnect the connector for the front switch control board. Try turning it on with the remote. If it works replace that board, also look for bad caps on the small signal board. they're 1000Mf 16v
Mar 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 52525 lamp replaced, no picture, red light
You have to take the TV apart. Pull the electrical chassis out and look for bad electrolytic caps on the boards. The red LED probably means the 2 - 3300UF caps on the power supply board are bad. You can tell if they are bad by the fact that their tops are puffed up and they may or may not be leaking brown fluid. Compare them against the other caps on the boards and you will see how they have flat tops.
BUT before you take the TV apart you can check the error codes by pushing "menu" and "Device" at the same time and holding for about 10 seconds. The status light will blink two numbers. ex. one flash pause two flashes is 12 Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
or use this table -
You can buy replacement caps from Mouser electronics online. There are plenty of solutions detailing how to do this already posted.
Jan 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The blinking status & Time LED lights
DM board n/l/a ....
the only and best way to fix this TV ! ! !
you need to replaced the chassis !!!!!!!!!!!!!!!!!
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Control board assembly (internal - not front panel)
Try reseting the remote.....hold down the power button...press 00, or 01....then release the power button......Or maybe the parental control is engaged...........On this model all the boards are interconnected in one shielded unit.....That a certified experienced tech wouldn't want to dis-assemble/reassemble in the home.
Jan 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsibushi WD-52525
yes if the lines are on all inputs and also on the menu of the set itself then you may want to test your 5 volt power supply on plug j19 of the lite engine.this does require removing the back of set along w/the back shield,about 30 screws.good luck joe tv
Oct 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
