Question about Logitech X-540 Computer Speakers
X-450 Speakers Pulstaing Sound
So, my speakers, every so often will start pulsating, like turning the volume control up and down over and over. It's really annoying, and whats even worse is that there are no drivers for the speakers. Any help will be appreciated :)
  • 2 more comments
  • monkidawg Dec 21, 2008
    Yes, my sound card has 5.1 support, and I think even 7.1. It is the SupremeFX II. I have looked, but not found any drivers for it, and the surround sounds great, it's just that the sound pulsates... :(
    Hope this helps
  • monkidawg Dec 22, 2008
    Motherboard: Asus Rampage Formula
    The sound card came with the motherboard, but is not connected. I can't find who made it...
  • JuSaCru Feb 19, 2009
    My speakers also have the pulsating problem. I have a Gigabyte GA-MA790GP-DS4H motherboard with a Phenom X4 processor. My sound drivers are up to date, and still no progress.
    Any help, please? Thank you.
  • Thomas F. Schneider May 11, 2010
    Your speaker system is for designed for the  5.1 sound.  Does you computer have a 5.1 sound card inside? Have you installed the driver for the 5.1 sound from the maunfactor of the sound system?
    President:
  • 2,692 Answers
I need more information. What mother board do you have, specific model please? Is the sound card intrgrated to the mother board or stands alone.  If alone who made it,and the specific model number?
Posted on Dec 21, 2008
Computer detects speakers but no sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 26, 2011 | Durabrand 5.1 Surround Sound Computer...
Speakers were working,then i pressed something to see if was gonna sound different and now i cant find my way back to what it was...sound is coming from the computer to the tv,,but external speakers have...
also
hope it helps
Sep 22, 2011 | Logitech X-230 Computer Speakers
My Yamaha YST-M101 speakers are not playing any sound at all. They are plugged in correctly and the green light turns on when I attempt to turn on my speakers. Help?!
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Aug 23, 2011 | Yamaha YST-M101 Computer Speakers
I cant get the sound to come out of my speakers. I have checked all conection, ect
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 01, 2011 | Logitech LS11 2 Speakers
I do not know my sound card but i know my motherboard that is intel pentium3, how can i found my sound driver? please help me,thanks.
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 28, 2011 | Intel Pentium 3 , 450 MHz Pentium III...
The speakers wont work no sound
This article contains tips for resolving sound related issues in Windows XP.
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 10, 2010 | Logitech V20 Computer Speakers
No sound my system
If there is no sound coming from your computer try these "simple" but common solutions first.
1. Make sure the power cord is plugged into an outlet and the speakers are turned on.
*Make sure your speakers are correctly connected to the computer.
*Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer.
2. Make sure your computer has a sound card and that it is enabled and working properly:
To open Device Manger...
*Start
*Control Panel
*System and Maintenance
*Device Manager
*Expand the Sound, video and game controllers category.
If a sound card is listed, you have one installed.
*Check the status of the driver and update if necessary.
3. Make sure that the speaker volume is not muted or turned down too low.
To open Volume Control...
*Click the Start button ,
*Click Control Panel
*Click Hardware and Sound
*Under Audio Devices and Sound, click Adjust system volume.
*Under Main Volume, move the slider up or down to raise or lower the volume.
If you still have no sound after checking the solutions above, you more than likely have a bad sound card.
Jul 13, 2010 | Computers & Internet
No sound conning out of speakers from wharfdale mixer
Speakers are working OK otherwise?
Do you get sound from headphone jack?
It's probably some pot control not turned up.
Is MAIN OUT turned up
Are speakers connected to monitor out or main out.?
Is gain for mic turned up?
Is there a MAIN OUT switch (on/off)?
Is there a MUTE control on the board?
Aug 05, 2009 | Wharfedale Force One Main / Stereo Speaker
Sound is Pulsating when music plays
Ahh, I have these speakers and its common when you have the volume knob turned all the way down, to fix it, turn the volume REALLY low in windows, so that way you have to turn the volume knob on the speaker control up to 50-100%. And you will have better sound..... No pulsing
Oct 02, 2008 | Logitech X-540 Computer Speakers
Computer Speakers
Try turning the volume on the computer volume control up and turn the volume control on the speakers down, or try the other way, turn the volume control on your speakers up, and the volume control on the computer down. I've had this problem before and this was the way I found a resolution.
Jan 05, 2008 | Audio Players & Recorders
Logitech X-540 Computer Speakers Logo
900 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
