Question about Maytag MER5775Q Electric Kitchen Range
Maytag model MER5755qaw glass top range
Just stopped working. The digital indicator clock does not come on unless I turn an eye on. When I turn and eye on, i can set temp for oven but it will not heat and the eyes will not heat. Indicator light for the glass top does not come on. When I turn the eye off, the indicator light blinks when it gets to off position, they everything dies again.
Noggin
  • 944 Answers
SOURCE: Oven not working properly
Do you mean 200 degrees Celcius or Farenheit? If Farenheit then the most likely culprit would be the thermocouple in the oven which can usually be replaced relatively easily by someone mechanically minded, if Celsius then you should suspect the elements although a working broiler would suggest that there is at least one element that works fine. Maytag says; "Why won't the oven heat up? First, make sure you've properly set all the oven controls. Check your user's guide for more information on your model's controls.(see below for the link to the manual if you need it) If your range offers the option of a delayed oven start, check to see if it's been selected. If so, the oven won't begin to heat until the selected time. If your oven has a lockout feature, check to see if it's been selected. If so, it will prevent you from using the oven. If your oven still won't operate, please contact an authorized Maytag service provider for more assistance." Here is the link to the manual; http://www.maytag.com/assets/product/8113P564-60.PDF and here is the link to Maytag Service if you need it - hopefully not; http://www.maytag.com/support/service_parts.jsp The other possible culprit would be the electrical supply to the oven - it may be adequate for the stovetop or grill but the oven may draw more power than the circuit can handle - even if it was fine before, this can change and may be caused by corrosion, rodents, overloading etc. and may not necessarily trip the breaker switch - if you suspect this at all then get a qualified electrician to check - it shouldn't take long to check so should be cheap, although repairs if necessary may cost more Hope this helps :)
Posted on Jun 22, 2007
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
memturbo
  • 226 Answers
SOURCE: Can you replace electric eyes with glass top?
there is more to it than just replacing the glass .
and I'm not aware of any kits that allow this .
Posted on Mar 27, 2009
shinn8
  • 85 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
Posted on May 18, 2009
mbnataraj
  • 84 Answers
SOURCE: Oven & broiler not heating on our Maytag
May be the heating coil is bust?
The control panel is in parallel usually so as long as the controls are getting power they will turn on. But if the coil is gone you wont get heat. If you want to try fixing it, you may need a multimeter, or a continuity tester.
Posted on Jul 08, 2009
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
Have Maytag MER5755QAW range, the oven will not heat up, the display was working isn't now, i check both elements and temp sensor, all ok
The display control will need to be replaced. It may be cheaper to replace the unit since the control is so expensive. Here is a link to the part you need.
Keep me posted!
Jan 21, 2013 | Maytag MGR5880BDS Gas Kitchen Range
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag MER5755QAW Range and the oven will not Heat
You said the broiler element which is the top element is working fine what about the botom element, needto check it, i would say its probally bad, also before you do anything be safe and unplug unit completely before checking
Feb 18, 2010 | Kitchen Ranges
I NEED TO REPLACE BROKEN GLASS TOP OF MAYTAG MODEL
ITS A LITTLE TRICKY, WHEN YOU GET YOUR NEW ONE LAY DOWN A OLD BLANKET PUT YOUR NEW ONE UPSIDEDOWN ON IT DISCONECT POWER THEN REMOVE YOUR OLD ONE .OPEN THE OVEN DOOR THERE IS 2 OR 3 SCREWS ON THE TOP OPENING HOLDING IT DOWN REMOVE THEM AND SLOWLY LIFT TOP UP AND SLOWLY PULL FORWARD. YOU WILL SEE A CONNECTOR TO DISCONECT ALL THE WIRES THEN LAY COOKTOP UPSIDEDOWN NEXT TO THE NEW ONE. SLOLY REMOVE SCREWS THAT HOLD BURNERS ON BRAKETS. I MARK THE HOLES ON THE BURNERS WITH A SHARPY
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 17, 2010 | Maytag MER5775Q Electric Kitchen Range
Change time on stove held clock button and got a 5Ab & can't chng
Loof for the tech. sheet in the unit , either in the control panel [top] or the bottom under the drawer. It should tell you how to enter different modes on your range.
Phil
Apr 10, 2009 | Maytag MER5775Q Electric Kitchen Range
I have a Maytag Electric Range/Oven The Range MODEL#MER5755QAW
best guess is thermostat I believe the broiler does not need the thermo in oven.. it stays on steady hot .. thats why it still works
Mar 12, 2009 | Ovens
Maytag MER5775Q Electric Kitchen Range Logo
229 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
