Question about Whirlpool Duet GHW9150P Front Load Washer
Washing Machine wont drain
I have an older washing machine that drains water for the most part.
It still leaves about 4-5 inches of water in the bottom of the machine, which when we get ready to empty the clothes and put them in the dryer we have to ring everything out by hand which takes even longer.
I have already checked the drain hose and it is clear. I have noticed though that if you put it on spin cycle, and then open the lid, it DOES NOT stop like it does on most machines. I know when you open it it is supposed to stop doing whatever it is doing, but this machine is NOT doing this.
PLEASE HELP!!!!!!!
  • 85 Answers
Remove bottom panel and check for obstructions in the pump romove cap by unscrewing but beware of water have some towels ready
Posted on Dec 19, 2008
Tip
The washing machine is draining but the water is coming back inside?
Check out this possibilities for water not draining in the washing machine: This problem relates to the hose connected to drain pump. The drain hose should not be in laundry tub more then 4 to 5 inches. Measure it and if it’s more then 4 to 5 inch then cut the excess hose in the tub. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly. But if the drain pump hoses are ok checked then this problem relates to slow drain of water from laundry tub. You can solve this issue by cleaning the drain pump blockages and dirt build up this will make the flow of water proper in the draining of the laundry tub.
This will help.thanks.
on Mar 18, 2010 | Washing Machines
Wont let water leave washing machien chequed filter its cleanhave to drain
YOUR PUMP IS BROKEN AND WILL NEED A NEW ONE OR IT CAN BE BLOCKED
Dec 27, 2013 | Washing Machines
WASHING MACHINE WONT DRAIN
1. check the drain knob if operational or functional. 2. remove the water and check the drain inside of your washing machine if something block it or dirt, like hair, or other small particles and if positive clean or remove it. 3. check also the filter if has then clean it also. 4.check outlet solenoid valve if has, maybe its defective and this is subject for replacement. 5.check the hose pipe drain if possible plug out to the washing machine, check it if clean or dent.
Feb 13, 2011 | Washing Machines
My wf t1001tp wont drain...can anyone help?
sounds like a blocked drain hose or a faulty pump motor..If the machine can be drained by putting the drain hose lower than the water level then the hose is not blocked and it may be the pump...Make sure the hose leaves the machine from under the tub and not high on rear of washer. Obviously water won't flow uphill..If the pump has failed a new pump motor is much cheaper than buying a whole new pump....Nomess
Apr 04, 2010 | LG WFT1071TP Top Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
I, Just got a new washing machine about 2 weeks ago it is a indesit WIB101. The Problem Is That When The washing is finished, the next day it still has 3-4 inches of water left in the bottom of the drum
i bassume the water is coming in after cycle finished. source can be two things.
water valve leaking - not probable on a new machine but to check, turn water off and see if water comes in.
if drain is plumbed into a spigot on the sink trap, when you empty the sink, some of the water will go down the drain hose. to cvure, take the drain hose up in a swan neck as high as possible
Sep 14, 2008 | Indesit Washing Machines
MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Whirlpool Duet GHW9150P Front Load Washer Logo
52 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
