Question about Acer AL2671W 26 in. LCD Television
Cannot set channels
To Whom it may concern
acer LCD TV...AL2671We cannot lock in channels,I go to menu, settings
then scroll down to scan.(This seems to be the only way to set stations.) Channels are set, but when you turn off it goes back to av etc,scans through dvd, then settles to fuzzy screen with channel setting 1 21 etc. This tv is 3 years old. We think the problem is as simple as just pressing wrong button and disturbing tuning.
Hopefully you can help
Tina O'donell
  • 3 more comments
  • tinaodonell Jan 27, 2009
    What is firmware??
    Can you please give me step by step instructions, I don't know what flashing means.
    Programme?.... is this the programme that comes up when I press menu?
  • tinaodonell Jan 31, 2009
    Hard to understand english, terms used for parts etc. But I appreciate the time put into my problem.
    Will need to get in the professionals unfortunately.
    Thank you
  • oolong_roshi May 11, 2010
    This is a normal issue that have this model, flashing the firmware again solve it.
  • Anonymous Mar 14, 2014
    see above
  • 3 Answers
It is the software or the program that have the TV to operate properly.  Sorry for my english.
Posted on Jan 27, 2009
  • oolong_roshi Jan 27, 2009
    You need special hardware to do it, and some knowledge, I talk about this issue in other treads of this section, read them, that is going to help you, but if you don't have the special hardware you can't solve it. You need a repair centre.
Accidentally set my TV to factory defaults
only digital signal is available now analog has been switched off no longer transmitting. You could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure . retune the digital channels only
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 04, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
46xbr kdl hi for some reason my tv as froze on channel 44...it is set in the programs list and i cant remove it...
you could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure
Jun 03, 2013 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
I have a problem to scan a local channel in Indonesia area with my lcd monitor hyundai L19T
is your lcd in english? what do you mean you ccant find indonesia on the menu? are you looking for the language or the indonesian channel? well if your looking for the language you should go the settings menu and go to language..from there try to find indonesia and enter,then the language will be indonesian..or if your wondering why you cant scan the channels on your lcd..you should try settings menu again and go to the channel set up..find auto scan and click it..then your lcd should be scanning and remembering all the channels thats been scanned,but before you do the scanning make sure that your antenna or your cable provider is connected to your tv..otherwise you wont scan anything
Jan 13, 2012 | Hyundai Electronics L19T 19 in. LCD...
I have a Grundig XENTIA 82 FLAT MFW 82-430/8 TV, everytime i turn it on i get a blue screen & the child lock nb to fill in, so i have to type the nb 7038580 to watch tv... how can i cancel this koz...
If this is happening on all the channels I think you will need a total reset. If so open menu and check the settings for child lock when you manually tune. An option is to reset the channels once again after the lock is opened. Choose a new channel scan to reset the memory. However if the lock seems to be only on specified channels you can open the settings of the channel and unlock on the menu.
Oct 16, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
I need code to activate my tv and channels
You probably need to SCAN the channels.
Connect the signal source to the tv. Either cable or Antenna.
Enter the menu mode on the tv. You can do through the remote.
Scroll down to the signal source. Select the signal source you have connected to the back of set.
Scroll to SCAN in the menu.
SCAN in the channels.
Exit menu mode.
You can now watch available channels.
Feb 09, 2011 | Televison & Video
How to scan for new digital channels small Philips flat screen
From the menu you should see set up the cannel scan should be there.. If all else fails unplug the TV for a few minutes then plug it back in. It should ask if you want to set up the tv, Say yes and follow the steps.
Jun 16, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
May 02, 2009 | Element Electronics FLX2211B 22 in. LCD TV
I have a Proview TV that we just bought from Rent A Center and when we connect our cable to the TV it tells us to scan the channels. We did this and still we get a blank blue screen that says No Signal....
Try this as your model is basically the same as mine.
Push Menu on your remote.
Then a small screen comes up.
Using your left right arrows move left to set up.
Scroll down to tuner mode and again using left right arrows, there are 4 setting you can choose. Once the setting you choose is showing then scroll up to Channel Searching and hit OK on your remote. This will scan all the channels Digital and Analog.
Depending on which of the 4 setting you picked on TUNER MODE you may have to do this again in the next mode to see which will get the most channels on your TV.
I hope this is helpful; Ken, Attica, NY
Nov 27, 2008 | Proview PA-32JK1A 32 in. LCD Television
VIzio channels won't change
press the menu button in the middle of your remote and scroll over to the middle tab that's labled "TV" and then scroll down to "auto search". click on this option by pressing the right arrow key on your remote so that your T.V. and "re-scan for channels. It might take awile. I took me about 5 minutes but for majority of the time it was stuck on 45% while it was scanning.
Jun 28, 2008 | Vizio L32 32 in. LCD HDTV
Samsung lcd faults
Found this on FixYa and it worked:
I had a similar problem and the way to solve this is to reset the set from the remote. Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Peter
Mar 10, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Acer AL2671W 26 in. LCD Television Logo
224 people viewed this question
Top Acer Televison & Video Experts
Rommel Balcita
Jaime Hernandez
Marvin
Marvin
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
