Question about Panasonic AG-DV1000 Mini DV VCR
AG-DV1000P that powers off when tape is put in.
I wanted to know if anyone can help me out. I have a AG-DV1000P mini DV deck. A problem just started with it when if I put an MiniDV tape in (even new one) as soon it loads fully threads up the deck powers off. When I turn power on it powers off again (tape still inside). Pressing eject button the second I try to press power on will eventually eject the tape. If I press play it powers off. Has anyone seen this problem and is there a solution that I can do? I am tech person but I just never worked on these decks. Suggestions welcome too. Thanks. I work for a place that can't afford to send it to repair right now but is a much needed deck so if someone can help me out it will be greatly appreciated. Thanks.
    Champion:
  • 221 Answers
I have seen a couple of these decks that had broken solder connections at the rear AC power connector.  the main board has to be removed to access the connections.
Posted on Oct 26, 2007
  • 71 Answers
Hi sir one of the reel or capstain motors should be not allowing to work something prevents it from rotating check with hands for fluidity of capstain or reel motor that power off is a conclusion of a short while motor tries to spin check for any thing broken in the guides or the path regards please don't forget to rate ,thx
Posted on May 04, 2007
Panasonic Ag-DV1000 mini DV deck shuts down after inserting tape
When there's a problem with the drive mechanism of a VCR it will shut down to prevent damage. All operations of a VCR are controlled by a computer chip. This is told what mode the mechanism is in by a Mode Switch. If this is faulty it can cause the machine to play up. Sometimes a spray of Video 40 on the mode switch can restore operation. However it will not correct the problem if the mechanism has any damage on it.
Feb 25, 2014 | Panasonic AG-DV1000 Mini DV VCR
Panasonic AG-DV2000 Mini DV VCR will not play large DV tapes
the problem of your player is the mechanism to dv tape slut(not mini dv)...it need to calibrate or to tune up...only can fix this is a qualified technician....
Aug 14, 2007 | Panasonic AG-DV2000 Mini DV VCR
Can I get a driver to connect the AG-DV1000P to my MAC 0S X 10.4.11
does the AG-DV100P have a firewire output connection?
If it does your mac should be able to 'when connected' have the driver of this machine built into the OS.
Feb 03, 2010 | Panasonic AG-DV1000 Mini DV VCR
DV Deck not loading tapes...wtf
most likely problem is a defective cassette housing. good service tech should be able to handle this with no problem.
Aug 29, 2008 | Panasonic AG-DV2000 Mini DV VCR
AG-DV1000 Mini DV
The message indicates that an internal problem was detected and that the unit has shut down to prevent damage to the tape. The tape will need to be removed by hand. I can not receommend a repair location without knowing where you are.
Can you post an update with your location?
Thanks,
Dan
Aug 19, 2008 | Panasonic AG-DV1000 Mini DV VCR
Error H U 11
U11 is a "dirty video heads" message. Either use a cleaning tape or have the unit professionally cleaned.
Feb 17, 2008 | Panasonic AG-DV1000 Mini DV VCR
Deck will not accept DV tape
most likely problem is a defective cassette housing. I've replaced about a dozen of these in AG-DV2500s.
Jan 12, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure for the inexperienced.
Panasonic AG-DV1000 Mini DV VCR Logo
424 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
