Question about Toshiba Satellite 1415-S173 Notebook
Cannnot open windows
Boot menu error
  • 2 more comments
  • lsisonpo80 Dec 19, 2008
    when i open the computer it takes time before the window to come out.then a blue background appear and a message say unmountable_boot_volume
    pls help with this problem coz i need for my job!all my wok is in there
    how do i do that! removing the hard disk won't be that easy!where is it located so that i would have the knowledge of doing the said task!
  • Donald
    Donald "Colt" Baldwin May 11, 2010
    I need to know what happens when the computer starts - does it go through its regular start up procedures (POST) or does it just stay blank.At what point when loading windows does it quit? What version of WIndows are you using? Is there an error message? Can you boot into Safe Mode?
    Master:
  • 569 Answers
I think you will have to try to install a fresh copy of windows i suppose you are using Windows Xp, try repairing it but dont press "r" when it tells you that there is windows loaded, press"r" on the second time, this might repair your os, but see that in any case u dont allow the computer to get formatted. if it tells you that the hard disk is corrupted and u need to format it dont format it cause u say that there is important data inside, so remove the hard disk from the computer and connect it to one of your friends computer take out your data and then format the hard disk and reload the software once again
Posted on Dec 19, 2008
My computer gives message "reboot and select proper boot device or insert boot media in selected boot device and press a key". I don't have a reboot disk.
That probably means the boot manager is missing or has an error. If the hdd is available in your bios, press F8 just before it would normally boot. There should be a menu that will allow you to repair windows.
Jul 24, 2014 | Computers & Internet
IM Communication Error error code = 200
usually it happen when you install a program in your unit that it's not compatible in your os. if you use a win xp try to reboot press f5 several times while booting you will see booting menu like safe mode, boot with network, last good know configuration.. chose the last good known.. and it will open you like when you haven't installed the one that damage your software
Jun 16, 2014 | Microsoft Windows XP Professional With...
Compaq presario sr1920nx--dvd rw lightscribe cannnot read or play dvd, compact disc; cleaned the tray, tried other players: real player, windows media player, sonic player, quicktime player
Assuming it powers on - since it sounds like you can open and close.. check 2 things - 1. run set up - press F1 while booting up for most pc... make sure your dvd drive is detected. if yes, 2 open case and make sure the data cable is connected on drive and the board.
May 19, 2011 | HP COMPAQ Presario SR5510F Athlon 64 X2...
My laptop wont boot up and goes to a system error with run set up and boot menu if you go to boot goes to the windows xp screen and then back to the system error 0203 faliure ide #2
Windows is totally corrupted and you must reinstall it. So either select the recovery partition from the boot menu or put in the recovery cd and select it and follow the instructions.
Jan 15, 2011 | Computers & Internet
End to end configuration errors appears constantly ? fix
You could try doing all the updates to Service pack 2 but i would seriously consider buying an upgrade pack to Windows 7 you'll it compared to vista. Please vote...cheers from Scott
Jul 04, 2010 | Microsoft Windows Vista Home Premium with...
How do i fix an unexpectedI/o error
Could be when windows uses transfer mode, you can change this mode
Steps To Change IDE Properties
Click the Start button
Right click My Computer
Select Manage from the resulting menu
In the Computer Management window, select Device Manager
In the right pane, click to expand IDE ATA/ATAPI controllers
Identify your CD/DVD drive in the expanded menu and right click the appropriate drive
Select Properties
In the Properties windows, click the Advanced Settings tab
In the Transfer Mode box that represents your CD/DVD drive (typically Device 1); open the dropdown menu and select PIO Only
Click ok and exit all windows
If this does not resolve your issue, then you will need to go back using the above procedure and change the Device 1 in step #9 back to "DMA if available". Then, change Device 0 to "PIO Only" in the Transfer Mode box.
For reference, the Device 0 is the Primary IDE Channel and the Device 1 is the secondary IDE Channel.
After you change your settings, make sure you restart your system so that the computer recognizes the changes you have made. After you reboot, check the settings to make sure they are in effect. If they are, your device should now work properly.
any further help let me know
Nov 05, 2009 | Dell Inspiron 1525 Laptop
Boot up problem..
i dont think the internet files had a difference.
a disk read error mean thateither you have a floppy in your computer or the hard drive is corrupt. that cannnot be fixed so i recomend getting a new hard drive.
Jaddude
Jan 07, 2009 | Dell Latitude D600 Notebook
Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529
More Info MS KB 927391
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
  • compact /U C:\bootmgr
  • compact /U C:\ntldr
Aug 28, 2008 | Computers & Internet
Windows giving blank window while opening PC
Try pressing F8 before while booting and run Last Known Good Configuration. Also try to boot into safe mode and uninstalled IE 7.
Let me know what happens.
Apr 13, 2008 | Computers & Internet
Toshiba Satellite 1415-S173 Notebook Logo
47 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
