Question about Intel D915GLVG Motherboard
The cpu doesnt start,experts say motherboard is dead
Earlier the cpu used to take 15 mins to start now it has stopped abruptly.switch is ok,smps is fine.
i showed it to a man he says the chips are dead.green chips heat up when given power
  • sid21 Jan 15, 2009
    LONG
    President:
  • 2,692 Answers
Replace the mother board.I found this model mother board still available from several different sorces via the internet for as low as $85.If you replace the mother board with the exact same one you hard drive and everything else will still work.
Posted on Dec 19, 2008
    Scholar:
  • 113 Answers
It happens when one of the component would not give the exact dc supply to its component near to each other and its so hard to replace a chips that has been broke down. okay, try this, although its to risky but theirs no other way to test your main board if its still good. if your video card is built in, plug the external video card. if your main board accept AGP or PCI then try them one step at a time. load the memory then try booting it again. if it still has no display bring it to a service center near you ask their assistance to make a series of test to your main board. Im sure they a device to test all the IC's and the chipsets. Good Luck!
I HAVE DISASSEMBLED MY PC TO CLEAR IT OFF FOR DUST IT HAS ON ITS SMPS & MOTHERBOARD. AFTER CLEANING WITH CLOTH & SOME LITTLE AIR BLOW. I ASSEMBLED IT AGAIN AND PUT THE CONNECTIONS AS EARLIER....
I'm no proffessional but when I have this problem I first think what may have caused it. Since your fan starts and then stops the power supply must at least be working. So it may have been something like your static electricity confusing the motherboard or something weird like that. It could also be that you tried to boot it up with some connection with the negative plugged in the positive and visa versa...that shouldn't cause much of a problem but you may want to research your motherboard and make sure it has the safety mechanism.
Anyways, I think the best thing you can do is remove any extra memory ram sticks you have and unplug all USB and the PW SW and all that and even the main power supply and then plug it all back in. Good Luck
Feb 27, 2011 | Gigabyte GA-G31M-ES2L Motherboard
My machine is not starting..CPU fan stops just after starting for 3-4 sec..I am sure that the CPU,RAM and SMPS are OK.Most probably the problem is in the MB.Kindly help me to solve the problem.I am using...
if your power supply is good and has DC output.....i have encountered a leaky capacitor at motherboard near the power supply connector socket...need to replace it esp. if it manifest bulgy appearance..it is a electrolytic type, replace w/ same value, it does affect the power to supply the MB due to fluctuation......try to test run after replacing it..have a nice day...
Feb 12, 2011 | Mercury P4VM800M7 Motherboard
P4B-M standby LED lighted and CPU fan jerked a little and stopped when power is plugged into the power supply unit. The motherboard does not seem to power up/ CPU fan remain still even the power switch on...
This is an issue with the power supply (SMPS) in your computer... Replace the SMPS will fix the issue...
It is not adviced to service the SMPS, because servicing the SMPS will not give proper power supply to the board, which may result in damage of Motherboard...
Dec 15, 2010 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Power supply works but pc doesn't power up no lights and fans dont work
Have you checked the power supply in different system? If yes then first replace CMOS battery and switch the CMOS battery jumper. And while doing this please unplug the hard disk or optical drive data cables and power. If it does not work then check the power switch is working or not or it is perfectly connected with the front panel PINS on the motherboard. If it is not connected perfectly computer will not start after pressing power button.
Second Level Test : Remove the CPU Fan - replace the CPU perfectly - again place the Fan.
Third Level (motherboard test): Just take the motherboard removing CPU,RAM, SMPS - use another same type CPU, RAM and SMPS - if it does not work so it is motherboard problem. If it works may be CPU problem.
Jun 12, 2010 | Gigabyte GA-8LD533 Motherboard
Mother board fault
NO problem about..... the mb..
its ok.. The problem may be with SMPS or motherboard...
Contact the from where you buyed your PC..
May 30, 2010 | Mercury P4VM800M7 Motherboard
Power turns off after a few seconds
Open your case, power up and then look at the CPU fan. If it spins normally, you may go to bios set up, look for Hardware Control, go to the fan subject and disable the function of watching CPU temperature or put it at the highest rank. If it does not help, you may think of RAM problem.
Aug 11, 2009 | Computers & Internet
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
Motherboard not starting!
try to set the jumper setting of the cmos battery in *********** board.you set the jumper setting 1 and 2 with in 3 mins.then try to set back the original setting the jumper seting in 2 and 3.
kira_ryuk99@yahoo.com
Jan 11, 2009 | ASUS K8V-MX Motherboard
Cpu not starting up....power 2 cpu from smps is ok..
hi most of motherboard power on pin is 6 and 8 just short these two pins once if mothernoard starts it;s giving display else check ram or smps otherwise motherboard faulty.
Oct 03, 2008 | Intel Motherboard
Boot-failure
I habe exactly the same problem. I habe the P45 Neo3 Board with E8400 CPU and 4GB Dominator RAM(1066MHz). No signal aber reboot. A Bios-Reset helps vor a Moment, but after Restart, i habe no signal.
Jun 16, 2008 | Intel Motherboard
Intel D915GLVG Motherboard Logo
83 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
