Question about Brother HL-2040 Laser Printer
'Speckled' Printing Hi, Just lately my brother laser printer has not been printing very well. It has a new toner cartridge and we have not done a great deal of printing through the new toner, though I would say we have broken it in. When printing, it is leaving 'speckled' ink and usually a few lines though the page. I have dusted the roller and both dry and wet wiped it over to no avail. Moreover, it just keeps printing the last letter I printed even though I am asking it to print something else. Can any one let me know whats going on?? The printer has been fab up until now. Kindest Regards, Mousie
  • Shelly Browne Apr 01, 2007
    Thanks for your response. I will look into it right away... as for the cleaning, I guess you never know these things until someone tell you :)
    Cheers,
    Mousie
    Just another quick question... How often should a drum want to be replaced?? I believe we have had ours for about a year and a half. The toner took a year to empty as well.
    In regards to printing, we are a small business, so it is getting fair-high usage.
    Kindest Regards,
    Mousie
  • 328 Answers
Do you have the owners manual? Did you cancel the document from the computer and turn the printer off for at least 30 secs. The speckled print and lines are usually caused by a defective toner or worn drum. Usually a drum will last for 10 thousand or more cycles. But sometimes prematurely wear out. Make sure you are absolutely using a genuine Brother OEM supply. Generics have a high failure rate. This is not a heavy duty printer. When you need a drum and toner together, it will be just as cheap to buy another low end Brother printer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 04, 2007
Printing with a grey speckled background
You're leaking toner somewhere inside the printer. If you've recently changed cartridges...
otherwise it might be time for a good cleaning, because once unfused toner starts moving around inside a printer you have to clean every roller in the paper path.
Apr 09, 2015 | Brother MFC-7840W Multifunction Laser...
Tip
Troubleshooting Laser Printers: Be sure all dip switches are properly...
Troubleshooting Laser Printers: <ul> <li>Be sure all dip switches are properly set for your configuration. Laser configuration is sometimes done by a control panel of buttons with an LED display that permits you to alter configuration memory. Be sure that the application being used is properly configured for the printer as set up.</li> <li>Fuzzy laser output could mean you have a dirty corona wire or you are running out of toner. Horizontal lines or splotches indicate possible damaged or dirty print drums or rollers. Since some of these components are part of the cartridge, a useful quick fix is simply to change the cartridge. </li> <li>If laser images seem disproportionately long or short, the drive motor may not be moving the paper through at the correct speed.</li> <li>Failure of a laser printer to go on-line might be a communication interface problem. It could also indicate a faulty control panel. Try powering up the printer with the cable removed. If it now goes to "ONLINE" (or "READY"), suspect the cable or its connector.</li> <li>If you are printing totally black pages, suspect a broken or fouled corona wire. If that is not the case, replace the toner cartridge.</li> <li>If the print appears speckled, it is probably the fault of the primary corona grid which is part of the toner cartridge. Replace the toner cartridge.</li> <li>If white streaks appear in your printing, shake the toner cartridge to insure an equal distribution of powder. If that doesn't work, clean the transfer corona assembly. Contamination on the assembly will prevent it from holding the electrical charge needed to attract toner from the drum.</li> <li>A repetitive pattern of printing defects, such as an identical smudge every 2 inches may indicate a defective fusing roller. Try cleaning it according to your hardware vendor's instructions. If that does not work, you may need to replace the fusing roller assembly.</li></ul>
on Mar 31, 2011 | Office Equipment & Supplies
Faded printing issues with Brother MFC-9320
Try cleaning the corona wire on each toner cartridge. This may help solve your solution.
If this does not help try another thing.
Try and replace the toner cartridge. Maybe your toner cartridge needs to be replaced. Usualy when printed images are light or pale a toner cartridge replacement is recommended.
To see how to replace your toner cartridges check here
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
I have cannon printer model L11121E, lately ,its not printing well, some of the matter comes up very light,unable to read, as if the catridge is running out, this is supposed to be laser printer, what...
The toner may be low or nearly run out. Remove the toner cartridge and give it a shake in a horizontal position, then replace the toner cartridge in the printer. This may give you a few more prints.
If not you need to replace the toner cartridge with a new Canon toner cartridge, or purchase a re-manufactured toner cartridge for your model laser printer. These re-manufactured laser cartridges are approx. half the cost of a new toner cartridge.
Feb 08, 2011 | Office Equipment & Supplies
Can someone please help me i have just printed off 400 prints with my brother hl 4040CN laser printerits brand new and its now saying my cyan toner has ran out this is impossible i am right in the middle...
Your toner usage will depend upon how much of each color toner is used on each page. (To conserve colors when printing in Black and White only, specify monochrome in your printer setup) <div>I had similar problems when printing publicity flyers. The toner cartridges claim to be good for about 2000 prints each, but I was lucky to get 3 or 400 pages when printing blocks of color. The TN115 cartridges hold significantly more toner, and the cartridges that come with the printer are TINY.</div>
Jul 06, 2010 | Brother HL-4040CN Laser Printer
Toner light is flashing and printing has stopped
Hello ,
This problem is a common issue and easily fixed.
When putting in a new toner cartridge, the printer usually automatically resets the toner count.
In a situation like this, the printer did not automatically do the reset and so we must manually reset the printer.
To manually reset the printer, first, remove the toner from the printer and separate it from the drum unit.
With the toner cartridge in hand and the brother writing facing you, look to the left side of the cartridge. You should see an arc shaped opening with a white tab in it.
The tab is set at the right position and must be pushed back to the left side of the opening.
To push the tab back, you must turn the grey gear attached to the front roller upwards as you push the tab.
Once the tab has been placed to the left position, the printer will accept it as a new toner cartridge.
Thanks,
Pat
Apr 01, 2010 | Brother HL-2040 Laser Printer
The printer quit printing and the toner light came on. Replaced the toner with a brand new toner and its still not printing. Recommendations?
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Mar 04, 2010 | Brother HL 5250DN Laser Printer
Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
Jan 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
When printing with my Brother MFC, the pages are dark.
Did you change the toner cartridge with a new genuine oem cartridge?
Do a report print <settings> page from the menu and check the 'Drum life' Bar graph. If close to, or at 0%, get a new Drum unit
Dec 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother HL-2040 Laser Printer Logo
1,336 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
