Question about Mountain Plumbing Mountain The "Little Gourmet" Heating Tank MT641
Little Gourmet Hot water tank leaks out small hole in tank bottom
I would like to know the CAUSE (and the cure) of water leaking out of the small (1/4 inch) hole in the bottom of the steel tank; because no water will emerge from the faucet now
  • Anonymous Apr 10, 2009
    leak from my 3 year old Little Gourmet hot water tank
  • 332 Answers
This is a condensate line and suprising enough most of the plumbers I go back after never hook them up they should have a hose off of them and led to a discharge area, if this is actually on the tank you will need to drain it and remove it and reseal it,
Posted on Jun 21, 2009
Does anyone know the dip tube part number for a Rheem Fury Gas 42VR50-40F water heater? Heater runs out of hot water far too quickly. Thanks!
certain water heaters had a tube that dissolved, you take 1/2 in. copper flare one end of it, drill a1/8 in. hole in pipe 4 in. below flare ,remove cold water nipple on tank install new copper tube, cut tube to 3 inches off bottom of tank depth , reconnect cold water supply you should be good.
Mar 23, 2016 | Rheem Water Heaters
WOULD SOFT WATER HAVE A BAD EFFECT ON THIS MODEL AS IT HAS RUSTY BITS
Hot water heaters are a collector of sediment. The proper care includes flushing out the collected debris through the low side drain faucet. The problem is the faucet is not designed correctly to carry out the needed task. If you are handy... turn off the water and gas or electricity to your water heater. Relieve the water pressure through the temperature/pressure relief valve on the side of the water heater tank. Once pressure is relieved close the valve. Determine if you have a 1/2 inch or a 3/4 inch diameter drain valve hole in the side of the tank where the drain valve is located. The drain valve can be removed with channel lock pliers, an 8 or 10 inch adjustable wrench, or a small 8 to 10 inch pipe wrench. Water will leak out the threaded hole while the valve is out. If everything is closed maybe 2 cups of water will leak out of the hot water tank as you check drain valve thread size. DO NOT take your time checking thread size. After you know the pipe thread size go to the hardware store ( Home Depot, Lowe's etc) purchase a short nipple (1 1/2 to 3 inch depending on available space) and a ball valve (brass) due to the water temperature. You will also need a brass adapter for pipe thread to garden hose thread (male both ends). This adapter goes into the ball valve to allow for the connection of a garden hose. Connect the pipe and valve together using the correct pipe thread sealant and install in place of the original plastic drain valve. Install pipe to hose adapter using thread sealant. With the ball valve in place turn the water back on. Gas or electricity back on. Connect a garden hose to the ball valve. Place the other end of the garden hose in a safe area as hot water and debris will be expelled through the hose. With water on, Gas or Electricity on and the relief valve closed actuate the ball valve to the full open position for approximately 3 seconds then close the valve. Repeat the open and close of the ball valve three times. Observe the debris that emptied out of the garden hose. You may be surprised at what you see. If the water runs clear, disconnect the garden hose the task is completed. You can wait until the following year to repeat the process. Your pipe and valve are now a part of the water heater, they may remain in place. Put the hose away.
Aug 31, 2015 | Water Water Heaters
Rusty smelly hot water
The rust can be from rusted pipes, and not necessarily tank:
New tank has new anode rod, and is NOT likely to be cause of problem.
Anode only protects the tank... not your steel pipes.
There are mathematical formulas for figuring what size and type anode is needed for steel structures like bridges and water heater and boat hulls... if anode is too small or deteriorated, or coated in calcium, or not electrically bonded to the steel surface, or if tank is not full of water or boat hull is out of water, then anode cannot protect the steel.
For more insight about problem:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://waterheatertimer.org/Replace-anode-rod.html
Gene h
Mar 20, 2014 | Premier Water Heaters
In sink erator instant hot tank leaking at the bottom of the tank
Must replace tank.
Insinkerator stainless steel tank does not have anode rod to protect against depleted tank wall.
Copy following link for tips installing under counter heater, and manuals for several different brands
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Add comment as needed and fixya will not send me email to reply with more detail
Jul 15, 2013 | Water Heaters
Tank
Insinkerator has stainless steel tank but does not have anode rod to protect against depleted tank wall.
Leaking tank means broken weld, and you must replace tank.
Add comment as needed and fixya will send me email to reply with more detail as needed
Jul 15, 2013 | Emerson InSinkErator W-152 Point-Of-Use...
I have an insinkerator hot water dispenser with stainless steel tank, and the tank is now leaking. I'm wondering if it can be fixed or needs to be replaced
Replace water heater if tank wall is leaking.
These things have short warranty period.
Stainless steel will theoretically last longer, but steel tank water heaters have replaceable anode rod to prevent rust-out.
Be sure to recycle the old metal.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Oct 29, 2012 | Emerson InSinkErator C1300 Chrome...
After connecting a drain line to the pressure relief valve of my MR85245 water heater, I now have water leaking badly out of the heating element door.
Turn off the electricity.
Turn off the water valve going into tank.
Open a bathtub spout to let hot water pressure off the tank.
Check top of tank for any leaks.
Open the top access panel and see if element is leaking.
Open bottom access panel and see if lower element is leaking.
The reduced pressure on the tank will slow the leak.
If element is the problem, you can squeak by for a while by turning on the hot water heater only when you need hot water.
Order the 'Marathon MR85245 replacement element' online
http://www.gpconservation.com/rheem/marathon-sp213670-titanium-4500w-lower-element
These elements may be available locally, but they are not the same as 'ordinary' tank-type electric heater elements that you buy at the hardware store.
Buy more than 1 element because the Marathon elements have problems.
One of the reported problems with marathon elements is the high price of stainless steel replacement elements.
Drain tank.
Replace element.
Another resource for water heater information is:
Nov 04, 2010 | Water Heater Innovations MR85245 High...
We have a Rheemglas Standard Electric Water Heater 81V400 B and it's leaking water from the tank and also the hot water only lasts for a short period of time. I've been reading and have read that the water...
if your water heater is leaking from the tank, and not around any fitting, then you will need to replace the heater.
you can flush the heater, once a year is always recommended, however once every 2 years is sufficient.
scale, and deposites inside the tank will cause erosion and eventually eat through the walls of the tank. not much you can do to prevent this. the steel in the new tanks just don't last like they ued to.
Sep 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Reliance 501 - purchased house a few years ago don't know how old it is - water is dripping from bottom near plate can feel a small rectagular hole with what seems a small piece of metal in the middle -...
unfortunately not, if the tank is leaking from the casing, it needs to be replaced. i would suggest, if your not paying water tax, you can run the tank for as long as you like, just divert the leaking water into a floor drain. but i do highly recommend getting a new tank. that drip can turn into a flood in a matter of days, all depending how bad the inner wall has corroded.
Jun 20, 2010 | Water Heaters
Mountain Plumbing Mountain The "Little Gourmet" Heating Tank MT641 Logo
604 people viewed this question
Top Mountain Plumbing Water Heaters Experts
rpar
Paul Carew
Gene Haynes
Are you a Mountain Plumbing Water Heater Expert? Answer questions, earn points and help others
