Question about GPS
My GPS Garmin 750 battery isnt holding a charge much any more. The warantee is already past. We just need a new battery ... what do you suggest?
  • 2 more comments
  • rlagold Jan 11, 2009
    I have the same problem. Where can you get a new battery? Can you replace it yourself?
  • Anonymous Jan 26, 2009
    I have the same problem. Battery is not charging. What is the suggestion?
  • Anonymous Apr 08, 2009
    I got the same probolem on my 750 and warranty has expired. Any reccomendations on where I can get the battery replaced or get the battery/tools shipped?
  • Anonymous Apr 28, 2009
    ditto - 14mo old 750, battery lasts 20 minutes
The battery is replaceable. Batteryship.com sells a battery for around 27 or 28 dollars and a 7 dollar kit. There are two small torq screws that can be removed with the screw driver provided in the kit. The plastic tool provided in the kit is used to pry open the the back cover after the two screws are removed. removing the cover takes some force after you can get your fingers in to pull it apart. Once the cover comes loose remove the wires attached to the Garmin from the battery and the speaker. Notice how the small plastic ends fit in from the battery and the speaker to make certain that the small ends go in correctly. The battery is secured with a sticky tape and has to be muscled out of the unit. The new battery can be secured with double sticky back tape or some of the saved tape from the old battery. Secure the back and replace the small screws and your in business. The battery requires charging. Good luck it worked for me and I'm an all thumbs guy
Posted on Sep 29, 2009
    Filmmaker:
    Uploaded 5 video answers.
  • 14 Answers
Here is a video demonstrating the replacement.
newpower99 sells a similar kit for 24.95.
http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+750
Posted on Dec 26, 2009
    Problem Solver:
  • 12 Answers
NewPower99.com sells a battery kit which comes with video instructions on replacing the battery, tools, and a new battery. It worked great for me.
http://www.newpower99.com/Battery_for_Garmin_Nuvi_750_p/garmin%20nuvi%20750.htm
Posted on Nov 28, 2010
Nuvi 750 battery will not hold a charge. Unit works fine if plugged into the auto power. What might the problem be? What is the estimated cost of repair.
Sounds like you just have a dead/bad battery.
You can check to see if your device was included in a recent battery-related recall here:
https://my.garmin.com/rma/recallLanding.faces
If your unit is not included in the recall and you are (or a friend is) handy, you can buy a replacement on the net and replace it yourself for around $25 (US Dollars):
http://vimeo.com/8387716
(There are other sources for the battery, I do know if the linked company is trustworthy.)
I'm not sure what Garmin charges for this type of service?
Oct 13, 2010 | Garmin nuvi 750 GPS Receiver
When pluggin to the car charger and turn it on. it's a low battery and it keeps turning off. it doesn't charge. garmin nuvi 750.
the battery is defective and needs to be replaced, if the battery is not any good then it won't work even when plugged to an outside power source, that is how this are set up, the battery is not user servicable, u must send it back to Garmin for replacement.
May 26, 2010 | Garmin nuvi 750 GPS Receiver
Turn on shuts right off already tried to reset?
The problem is either a dead battery - and the only way to know is to charge it for sure - in a wall charger. Many cell phone chargers etc will work- other wise - you must charge it in the car charger - this takes at least 20 minutes.
If your battery will not charge - I suggest you send it to Garmin for servicing.
Also a new Garmin 285WT is on sale at Tiger Direct dot com.
Gary
May 06, 2010 | Garmin nuvi 200W GPS Receiver
Charger does not charge and battery is draining for Garmin Nuvi 750. What is the problem?
Check for power at the cord. Then check for power at the rectacle. If you have good power but it still doesn't charge, send to Garmin for repairs.
Dec 17, 2009 | Garmin nuvi 750 GPS Receiver
Need to replace battery in nuvi 750
Is not wery hard if you have tools to open .
Try here for battery www.satnavservice.com
Aug 31, 2009 | Garmin nuvi 750 GPS Receiver
Garmin nuvi 750 battery does not hold a charge
A new battery can be purchased and installed inexpensively. I found a video.
You-Tube video "yxP4PdRB_98" placeholder (do not delete)
Jan 26, 2009 | Garmin nuvi 750 GPS Receiver
Battery on Nuvi 750
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 19, 2009 | Garmin nuvi 250W GPS Receiver
Will not turn on
Hold the off button (to the left) for 10 seconds... the system will restart and your garmin should work fine!
Sep 13, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Internal battery won't charge
Common issue. Steps to troubleshoot/solve:
1. Pull off face, press reset tab.
2. If unit wont turn on or if turns off immediately, connect to home computer using mini usb on side of gps (any usb cord that fits will do). This will charge the internal gps battery, which is discharged.
3. You will not be able to see the gps charge indicator while the usb cord is plugged into the unit. To check charge level, disconnect it, turn it on, and note the large "battery" icon.
4 Do you have a dead internal battery? If the gps holds a charge from your computer usb port, you don't.
5. If you have a dead battery, Google DIY replacement. With some soldering it can done for $15 total.
6. If you don't have a dead battery, the issue is charging from the cigarette lighter socket. Your car socket may have blown a fuse (check car manual). Your charger unit may have blown a fuse (unscrew the tip, check fuse inside). Also, some car sockets don't work when the ignition is off. Test yours.
7. There is a good chance the connection of the charger wire to the gps cradle is the problem. Fiddle with that. Replacement cradles are available for the c340 at about $25.
8. If your unit is not charging from the cradle/socket, buy a 12v usb cord. Plug into socket and into usb port of the gps. This is a workaround or alternative to buying a new cradle.
9. IMPORTANT: observe the "battery" icon while driving, esp. if you have doubts about charging. Basically, if you can see the icon, you're not connected to an outside (car or computer) power source. That is, if you can see the battery-charge indication, it means your battery is currently discharging and unless you get another power source to work it will be dead in a few hours.
Aug 27, 2007 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
1,145 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
