Question about Sony Xplod XM-1652Z Car Audio Amplifier
Took out my amp and sub put it back in and now it wont work
I took out my sub and amp and i put it back in with new 4gage wire and rca's and my led light wont come on unlees i put some of hte power wire on the rem and than it sounds like im geting 2 much power to the sub "sounds like crud" than the light turns red help me plese
  • alex johnsion Apr 02, 2007
    but when the red light comes on no amp or sub they wont work
8 gauge reccommended make sure all connections are good and clean try new remote wire and make sure ground is less than 10 inches also being 8 gauge wire
Posted on Jun 05, 2007
You masht seting all parameter too the midel befour selected oan by oan,step by step equalayzer
Posted on Mar 30, 2007
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
No sound
hi there
on your CD deck or what ever unit you plugged the RCA wires to needs to be set on subs the radio needs to be set to put sound to your amp.....on your CD player if you press the F/function button a few times it will scroll to SW which is for the subs set this to the on position or if your CD player has a button with SW press it and turn on this feature......if this has been done......check the fuse or fuses on the amp.......if you have done all of the above check the back of the CD unit to make sure you are plugged into sub-woofer RCA or R (rear) RCA ..........sometimes people accidentally put the RCA wires into the aux input RCA,,,,,, double check this.........
hope this helps
Mar 07, 2009 | Crunch PZi1000.1 Car Audio Amplifier
Only get sound wen rca's r in halfway
You have a bad set of RCA's. Try and get a pair specifically made for car audio. There are hundreds of brands, usually the cheap ones work fine.
What usually happens is on cheap RCA cables, wires inside the actual plug split apart and short out on one another. Get another set of cables and you'll be fine.
Jan 30, 2009 | Alpine MRP-M450 Car Audio Amplifier
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
No sound
did you set your gains and base boost also when you put sterio back in dash did you put rca's on proper outputs or the rca's could have pulled out when putting back in
you have high output and low output
are your subs getting sound to them at all any current going threw speaker wires to subs
radio settings might not be set to back end for subs this is a feature on most receivers to shut off back end subs
May 08, 2008 | Kicker KX200.4 Car Audio Amplifier
Amp issue
rca cables and connectors
Aug 16, 2007 | Orion 3002 Car Audio Amplifier
The first thing to try is disconnecting ONE of the two subs. See if you get more bass with a single sub than with both. If you do, re-connect the second subwoofer, but reverse the (+) and (-) wires.
Jun 19, 2007 | Panasonic MXE CQ-C7401U CD Player
My 7801 doesnt turn on
check pwm circuit amps turn on with 3-4 volts on mosfet gates ic 494, 5252or 555 controll these.hit me up for more
Apr 03, 2007 | MTX THUNDER7801 SUPER AMPLIFIER CLASS D...
Sony Xplod XM-1652Z Car Audio Amplifier Logo
142 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
