Question about GE Profile PDW9880NSS Stainless Steel Dishwasher
Lights-up, but won't turn on (start/restart)
Have a GE Profile dishwasher with smartdispense and when I hit the start/restart button, it won't turn on. All the other lights are on, but the dishwasher won't start. Had problem with the same strip in past -- was under warranty and GE replaced the strip. Old problem was that I couldn't change cycle, now the thing won't start. Thank you for your help.
SOURCE: GE Profile SmartDispense clog
I have the same problem and found the below on the GE website. It says to purge the detergent from the Smart Dispense. I am in the process of doing it now...we'll see if it works:
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Posted on Sep 16, 2008
SOURCE: GE Profile Dishwasher Not Cleaning
We just hooked up our dishwasher. We used the cascade pillow packs. It worked great.
Then I thought I should use the smart dispense. I did the dishes are dirty and filmy!!!
I think the solution is once you get the dispense clear ONLY use the cascade pillow packs and for go the smart dispense.
UGHHHHHHHHHH
Posted on Oct 21, 2008
ginko
  • 19396 Answers
SOURCE: GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Posted on Mar 13, 2009
jumptrout51
  • 3361 Answers
SOURCE: Put wrong soap in the SmatDispense container...
If you run it as is you will have a kitchen full of soapy water.
Take a pot or pan. Fill it with COLD water. Our it into the DW. Fillit to the regular water level, about 1 inch below the bottom rim.
Set the DW to a pump out setting and drain it.
You will have to repeat this several times to clear the soap out.
COLD water pump out. Cold water pump out etc.
Do not use HOT water. You will get instant suds and lots of them.
Posted on Mar 27, 2009
ginko
  • 19396 Answers
SOURCE: GE Profile dishwasher with ''SmartDispense'' technology is clogged
Check the reservoir hose , and unclog it if necessary. You may need to disassemble the reservoir/dispenser to solve the problem.
Use to the diagrams below:
Posted on Apr 06, 2009
Replace rubber seal
You don't give the complete model number. If you are referring to the tub gasket that surrounds the opening (on three sides) when the door is lowered, it is held by friction in its groove. If it doesn't stay in place when fully pressed in, replace it with (most likely) WD08X10032.
Nov 08, 2013 | General Electric PDWT380VSS GE Profile...
GE GLD6700N dishwasher won't drain
remove the drain hose and make sure its not plugged with food debris then hit the drain/cancel button and put the drain hose end in a bucket and see how much water comes out of the end of the hose if any,if the 2 green lights are flashing this too is a clue to this problem,also make sure you can hear the drain pump running when you start it as explained in the above statement
Oct 16, 2012 | GE GLD6700NBB / GLD6700NWW / GLD6700NCC...
GE Dishwasher Won't turn on
Door may not be fully closing for some reason.
Mar 15, 2012 | General Electric GE Profile Dishwasher 24...
I have a GE Profile Dishwasher... it's about 5 years old (Model # PDW7880J03SS). It has a front control panel. This morning, only half of the lighted buttons work. The left side does not. I have hit the...
I have a GE profile model number pdw8200jbb . Only two lights appear on the touch panel. The stay on for a little while after opening and closing the door and then go off. Any suggestions
Jun 27, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
My GE Profile dishwasher won't start. The power
More then likely the Control Panel has faulted and will need to be replaced. You can try shutting off power for a few minutes and see if it resets.If so great if not time to replace.Not that hard of a repair for a DIY
Jan 08, 2018 | GE 24 in. Profile PDW7800 Built-in...
Apr 06, 2009 | Dishwashers
Mar 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Jul 01, 2008 | GE 24 in. Profile PDW9200J Built-in...
GE Profile PDW8800
Try replacing the water inlet valve.
Nov 12, 2007 | GE 24 in. Profile PDW7800 Built-in...
GE Profile PDW9880NSS Stainless Steel Dishwasher Logo
109 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
