0.584.004. FCC ID is: QFA-FRC584001 that is all I have to go off. My fireplace remote won't work and I can't use the fireplace to heat my home unless I turn it on and off constantly. Otherwise it is way too hot or freezing
  • 5 more comments
  • Anonymous Dec 20, 2008
    New house, no owner's manual for the remote. Logic is not making it work.
    Any ideas?
  • mdatngold Dec 24, 2008
    I have the same problem with the same unit for our fireplace remote control. Our remote has a crack in it, but I have no idea where to get a replacement.
  • collinsdwayn Jan 19, 2009
    mine also now it gets where its burning the fake logs
  • Anonymous Jan 27, 2009
    Same exact problem. Remote just stopped working, even though I've changed batteries in the remote and in the receiver in the gas logs. Anyone have a clue what the problem is?
  • Anonymous Feb 01, 2009
    I had the same problem with my new remote that would turn itself off after 6 hours in the auto mode but not the manual mode. I had it replaced, new one did the same thing. I complained again to my local trusted heating/cooling company. The tech called the company ( firegenie) who stated that the new remotes turn themselves off after 6 hours if the fireplace stays on the whole 6 hours. If it cycles off and on, no problem. This is consistant with the behavior of my system.
    I don't know if this is a company policy or an FCC one but it is a nuisance. It would make more sense for this to occur in the manual mode, but it does not. This is quite irritating and seemingly unnecessary.
    I have been tempted to by a new remote online, but if this is an FCC regulation, it would not matter.
  • befranz109 Feb 26, 2009
    the remote does not turn the fireplace on or off any more. The remote seems to be functioning properly , It indicates the fireplace is on when the temperature is above the room temperature,but the flame is not on. I have replaced the batteries, and even tried to reset the codes per the manual. Appears to me that the reciever on the fireplace is not picking up the signal.
  • pro_max1 Feb 28, 2009
I had the same problem. Just came home one day and tried to to turn the fireplace on and got no beep and no fire.Not sure if you still need this but I just finished repairing mine by trial and error. This might work for you so give it a try. If you look at the rear side of the receiver (left black box on the left side of the fireplace insert) you should see a series of white dip switches. I turned them all to the off positions and now my remote works.
Posted on May 06, 2009
  • Rob Wright
    Rob Wright Nov 28, 2013
    PERFECT! That fixed my problem too! Does anyone know who the manufacturer is of the fireplace?
I had the same problem. Called factory tech rep and he told me to reverse the polarity on the receiver by switching the wires. It worked.
Posted on Apr 03, 2009
Might not solve your problem, but we had a similar situation and needed to "reboot" the remote by removing the batteries for a minute (to make sure all the stored electricity is discharged) and then reinserting the batteries. We took that opportunity to replace the batteries.
Remote has been working just fine since.
I think these units may be sensitive to battery voltage, and when the batteries start draining down, the remote misbehaves.
Posted on Jan 14, 2009
I purchased a mantel fireplace from Fingerhut last March. The name on fireplace is FEBO FLAME. Now the on switch lites on but theres no flame or heat. The buttons on fireplace or remote do nothing. Id...
Since it can be a potential hazard, it must have safety protocols in place. If you have the owners manual, Read it's instructions carefully. Look through manual for TROUBLESHOOTING then look for safety locations, there you should find all the answers to your questions. Good Luck too you.
Jul 05, 2017 | Heating & Cooling
Remote won't work unless next to fireplace.
There are some adjustments that can be made to improve the reception of the Skytech 3301 Fireplace Remote.
Sometimes the RF reception can be diminished if the receiver is in an enclosed metal surround such as a heat shield.
The link above will bring you to the product page where you can scroll down and download the full owner's manual. An excerpt from the manual in regards to adjusting the reception is below:
NOTE: The slide button, Gray or Black, covers the ADJ access hole when installed.
A. To adjust at the receiver, use a small slotted screwdriver. Turn the adjustment screw counter-clockwise
about 5 degrees or a maximum of 1/8 turn. This should correct the distance problem.
B. If that does not correct the problem, return adjustment screw to original position and then turn adjustment
screw clockwise.
This adjustment is like tuning your radio. If you keep turning the adjustment screw, in either direction, you will go past the proper setting (tuning)."
Dec 25, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Remotes suddenly stop working #85095-01, and FCC ID IN2TX13
1) clean the contacts batteries, with cleaner contacts
2) tight the spring contacts with pliers for better contacts
3) resolder the wires connector from contacts batteries
4) open the remote c, and clean the keypads with contacts cleaner
God bless you
Jul 02, 2012 | Hunter 27185 Remote Control
I have the recall gas fireplace with model number starting with 794 it needs a thermo pile iam told. how do i find this part?
Hi try national energy or local plumbing / heating shop they will sell you one , home hardware home depot
Feb 10, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Need instructions to my transmitter
I have the same problem. The company is out of business DESA Heating. I have been unable to find a solution. FMI bought part of DESA but can't get any help there either. 1-866-328-4537
Jan 18, 2009 | Heating & Cooling
My remote won't start the fire in my vent free fire place.
Mine did the same thing. What happens is when the batteries die and the remote sits, the remote loses its address. I found this link to the remote manual online. You have to locate your receiver in the fireplace insert. On the receiver there is some dip switch settings. Open up the link below and go to the appendix at the bottom and find your address of the receiver, mine was 005. Go to your remote and power on. Hit the up arrow until you are at the timer. Now hit the left arrow on your remote 10 times, this will diplay the address of the remote, mine was 000, change this number to match your address of the receiver by hitting the up arrow on the remote, I changed mine to 005. Now hit the left arrow again and this will take you out of programming. Power on your remote and should work, enjoy.
Nov 25, 2008 | Heating & Cooling
I cannot get my remote to start up the fire place. It worked fine last year, but now it doesn't turn the fire on. It's remote unit FRC 0.584.004. Fcc ID is QFA-FRC584001.
There is batteries in the remote and at the loggs. Replace both. Mine had a black box under the logs on the left side tht had 4AAA batteries. Be carefull that the wiring is not pulled loose.
GTI fireplace with remote
The remote controls have two batteries. The one in the receiver was dead. It, turned the fireplace on. Because the remote overrides the ON/OFF switch in the fireplace--I could not turn the unit off. I did not know this. Did not know that a dead battery could turn a fireplace on. I think this is a safety issue because I am not always at this home. The remote was made in China. Stupid design and I will have to do more to cure this problem. I may bring the situation to Consumer Safety. Fed. Gov. because I can't be the only person with the problem. No manual came with the remote. Hence no warning.
Sep 10, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
1,810 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
