Question about Fuji FinePix 2650 Digital Camera
Timer How do you set the timer on the camera
  • 667 Answers
In camera mode, use the menu button to set the self timer on. It only stays on for 1 picture. 10 second delay I believe, once you release the shutter.
Posted on Mar 22, 2008
How do i set my camera to self timer mode?
Press the bottom part of the ring around the Func/set button, then scroll up/down for the timer function you want (single shot, continuous settings, timers,). Press the shutter to start the timer.
Dec 10, 2010 | Canon PowerShot A540 Digital Camera
How do I use the timer on my camera?
Select the timer mode (left arrow on the 4-curser-button). There are 3 settings in the order of 10sec timer; 2sec timer and timer off. Select either the 10 second timer (if you want to be in the picture) or the 2 second timer (more appropriate for long exposures when camera is on a tripod or similar to avoid camera shake when pressing the shutter button), then press the shutter button fully. The subject will then be automatically focused just before the picture is taken. There's a little light on the front of the camera (top right hand corner when you look at the camera) which should blink when self timer is activated. Pressing the menu button while timer is activated will cancel self timer mode.
In low light conditions this light may turn on brightly to double up as an AF assist light.
Hope that helps
Jul 24, 2010 | Panasonic Lumix DMC-FX9 Digital Camera
How do I set the self timer on my cannon a560 camera?
Press the self-timer button to cycle through self-timer settings. The rectangle indicates normal shooting, the clock indicates self-timer. Depending on the shooting mode, you may also see overlapped rectangles for continuous shooting.
To change the delay time, select [Self-timer] from the Recording menu.
The self-timer button is the same as the down-arrow on the circular multi-selector, marked with a clock.
Jul 20, 2010 | Canon PowerShot A560 Digital Camera
Press the the stopwatch symbol (Down button) repeatedly to select self-timer. Custom timer parameters can be defined by pressing MENU and selecting self-timer settings with FUNC.SET key (central button).
Oct 29, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
How to use the timer on a sony cyber shot 7.2mp digital camera
On your Cyber-shot DSC-W55 locate the control button:
32864f9.jpg Using the self-timer
Press cd9ebdc.jpg on the control button repeatedly until the desired mode is selected.
Conditions of the self-timer lamp:
(No indicator): Not using the self-timer
fc274e6.jpg: Setting the 10-second delay self-timer (picture is taken after 10 seconds)
996d00d.jpg: Setting the 2-second delay self-timer (picture is taken after 2 seconds)
Press the shutter button, the self-timer lamp flashes, and a beep sounds until the shutter operates.
Hope this helps.
Thank you.
Oct 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
I cant figure out how to set the self timer on this camera
If you press the left < button on the camera before you take a picture you will have the option to set the self-timer. The options that you can choose are: 1. Single shot; 2. Continuous shot; 3. Self-timer (10 sec) / Remote control; 4. Self-timer (2 sec); 5. Self-timer (10 sec): Continuous (2 - 10 shots).
Hope this helps!
Please rate!!
Cheers
Oct 01, 2009 | Canon EOS Rebel XSi Digital Camera
Set the timer
  1. Place your camera on a tripod and prepare your scene.
  2. While in a shooting mode, press the timer button (the bottom button in the circle set on of the back of the camera). Press it repeatedly. It will cycle through self-timer and remote-control. On the screen, a Timer will appear for the self-timer and a little Remote with a lightning bolt will appear for the remote-control. Stop pressing the button when the timer appears, pause for 3 seconds to allow the camera to confirm the setting the icon will disappear.
  3. These instructions are described on Pg 55 of the manual, but I will repeat them in simplified form in case you don't have the manual.
  4. Once the timer setting is set, press the shutter-release button fully. If you press it half-way it will focus and lock the exposure, then press it fully.
  5. The self timer/remote control lamp will light for 10 seconds. Get in position in the scene, after the 10 seconds the light will begin blinking. After 2 more seconds, the picture is taken.
  6. To cancel the timer mode, press the Timer button again; however the timer mode is automatically canceled after one shot.
It is important in all timer scene shots with cameras, don't stand directly in front of the camera because this will then focus on you instead of the scene.
Jan 21, 2009 | Olympus ? Stylus 500 Digital Camera
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Timer on samsung digital camera?
Sure ... be sure to use a tripod or other device to place the camera for stability.
  • Set the MODE DIAL to your desired photo setting
  • Press the SELF-TIMER button on the button pad (looks like a clock/timer on the right button pad)
  • There are three settings
    • 10 SEC - 10 seconds will pass until the picture is taken
    • 2 SEC - 2 seconds until the picture is taken
    • Double self-timer - a picture will be taken after 10 seconds, and then after 2 seconds a second picture will be taken.
  • Press the SHUTTER button to begin the timer.
  • Jump in the shot! =)
Please rate FixYa! ThankYa!
Dec 15, 2007 | Cameras
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Fuji FinePix 2650 Digital Camera Logo
47 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
