Question about Fitness Quest Eclipse 1100 Hr/A Elliptical
LCD not working for Eclipse 1100HR/A model
Even after changing new batteries - LCC not displaying or starting on Eclipse 1100HR/A model -
  • 3 more comments
  • kokomogator Dec 30, 2008
    My display is not working either although this machine has had very little use and never showed a problem. When I added new batteries, it came on for a couple of seconds then the lcd started fading and died. any help would be appreciated, it is over a year old so not still under warranty.
  • kdene Dec 31, 2008
    I am experiencing the same thing.
  • Anonymous Jan 22, 2009
    I have the same problem. Tried different batteries and even double checked the connections from when I assembled it.
  • mvm711 Feb 04, 2009
    Same here...
  • Anonymous Mar 25, 2009
    Mine went completely dead but we had purchased the extended warranty. I got in touch with the warranty company and they sent out a new LCD but the problem is it's not anything like the old one and the wiring is totally different. I hate after market warranties. What a waste of money. Machine is 3 years old.
3 Suggested Answers
SOURCE: the program monitor on my eclipse 1100hr/a
After about 4 years, one day my monitor just wouldn't turn on. After making sure the batteries were new, I took out the four screws on the back of the monitor and made sure the two wire connections were tight. They were, so I called Fitness Quest customer service (1-800-321-9236) from their website (fitnessquest.com). For about $120 including shipping they sent me a new monitor. It took me about a minute to undo the old, plug in the new, and now it works great! The flat connection with the multi-colored wires requires a gentle squeeze with a pliers on the sides while you glently wiggle and pull it apart. Look at the new connector to see how it should come apart. Good luck!
Posted on Jan 16, 2010
  • 3 Answers
Check it out. If you machine monitor shows and e-1 when trying to turn on. Take out the batteries and unscrew the four screws on the bottom of the monitor unplug it from the elliptical. Put the batteries back in turn on monitor the plug it back to the elliptical while still on and screw back in places. It worked for me hope it works for you too.
Brian Pickens
Long beach ca
Posted on May 04, 2011
Minolta di3010
LCC Shift Failure
• The Shifter Return Position Sensor (PC11-LCC) is not unblocked even after the set period of time has elapsed after the shift operation has begun (shifter is moved to the right). • The Shifter Return Position Sensor (PC11-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the shift operation has begun (shifter is moved to the right). • The Shifter Home Position Sensor (PC12-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the shift operation has begun (shifter is moved to the right). • The Shifter Home Position Sensor (PC12-LCC) is not unblocked even after the set period of time has elapsed after the return operation has begun (shifter is moved to the left). • The Shifter Home Position Sensor (PC12-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the return operation has begun (shifter is moved to the left). • The Shifter Return Position Sensor (PC11-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the return operation has begun (shifter is moved to the left).
1 Check the connector for proper connection, and correct as necessary. 2 PC8-LCC sensor check. 3 PC11-LCC sensor check. 4 PC12-LCC sensor check. 5 Replace PWB-C1 LCC.
Sep 09, 2014 | Konica Minolta Office Equipment & Supplies
I need replacement rollers under the foot pedals on a Eclipse 1100HR/A
Dave's solution-method is helpful--try to find parts that serve the purpose--perhaps even proving better. Given success, that's a really good idea!
The company failed--thus, no company product support or exact company replacement parts prove available for us anymore.
Try very specific, exacting online search queries for such parts (or, those analogous and proving even more intellgent) as you mention--search amazon directly in the same manner, as well. See if video sites offer any instruction. I hope that each of you may succeed.
Dave and the original anonymous poster: Please keep us informed as you make any progress!
Apr 04, 2014 | Fitness Quest Eclipse 1100 Hr/A Elliptical
1100hr/a control unit
Try cleaning (and/or fixing) the one you own: http://www.fixya.com/support/t24425996-get_timing_circuit_or_circuit_board
Otherwise, it's virtually hopeless: The company failed.
Feb 04, 2014 | Fitness Quest Eclipse 1100 Hr/A Elliptical
2008 Mitsubishi eclipse radio not working after battery change
Unfortunately in newer vehicles, they sometimes need to have the computer re-flashed IF you unhook the battery with the radio on. It's a crummy deal. The dealership will probably have to re-flash the computer. You could try turning the stereo off, then disconnect the cables on the battery for a minute, then re-connect and POSSIBLY it could reset the system and it may work again. Don't get your hopes up, this may not fix it.
Nov 11, 2012 | 2008 Mitsubishi Eclipse GT
Pharmacia Lkb Controller Lcc-501 Plus problem
Someone has pressed the reset button at the back of the unit. The memory banks are being cleared and all settings are set to default. Wait until the process finishes (hour maybe) and till the "check code 191" is displayed. This means that the restore to factory settings is finished. After that you should be able to use the unit again although all your programs are lost.
Oct 30, 2012 | pharmacia Science & Laboratory
New Eclipse mp3 player model 180 sl worked perfectly for a few hours now is froze on the Eclipse logo page. I have tried resetting by holding the start button for 30 seconds, and in excess of 30 seconds to...
most battery's in mp3 players are sealed in its case u can get repair kits from ebay for this salution,have u tryed restore from your computer, since its new take it back too the store u bought it from if used try my ebay salution..
Apr 09, 2011 | Mach Speed Eclipse 180SL 4GB MP4 ...
The program monitor on my eclipse 1100hr/a elliptical trainer does not work, what may be the problem?
Jan 03, 2010 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Monitor panel
You can download the manual here:
http://www.fitnessquest.com/scripts/cgiip.exe/WService=fq/story.html?article=3079
Mar 05, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
ECLIPSE 5443 DISPLAY DONT WORK
Hi Rozz,
That is the LCD screen and the backlight has evidently burned out. See if you can find a broken Eclipse of the same model on Ebay and replace your LCD screen.
Mar 21, 2008 | Eclipse 5443
Fitness Quest Eclipse 1100 Hr/A Elliptical Logo
127 people viewed this question
Top Fitness Quest Sport & Outdoor - Others Experts
Joseph Mueller
Joseph Mueller
Dave Callender
Dave Callender
Rigger
Are you a Fitness Quest Sport and Outdoor - Other Expert? Answer questions, earn points and help others
