Question about AEG T57800 Electric Dryer
Lighting the pilot
How do I light the pilot on a whirlpool dryer model #LGN20000KQ0? It's a front loading dryer, it's working but no heat. thanks!
  • 85 Answers
There is no flame type pilot. when you turn on the dryer remove small cover on lower left front panel to view if you see a orange glow, which means your ignitor is getting power listen for 1ckick sound and then a second after the ing glows. there a few things that could be bad ignitor. soleinods on the gas valve or a bad thermal fuse
Posted on Dec 19, 2008
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Whirlpool Dryers
My Whirpool dryer Model LGR 563 isn't heating now. Does it have a manual or electronic pilot light? I don't see a pilot light lit through the hole.
heatman101
Apr 24, 2011 | Whirlpool LGR5636PQ Gas Dryer
Dryer quit heating runs fine it is a gas dryer
Is the pilot light or "stricker" working when you start the unit.. Is it getting good supply of gas?
Mar 12, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
Where can I light the pilot
You're dryer has an ignitor not a pilot. To check, either pull the lower front panel or pop out the key hole. Start dryer and watch if the ignitor comes on it should shine brightly almost white. If it does'nt light at all(should at least turn red). there could be no voltage to the ignitor.
Jun 19, 2009 | Whirlpool Dryers
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Where is the pilot light on the Whirlpool Ultimate Care II Dryer?
Hello gigiknoll
Welcome to Fixya
My name is Huum,
This model should be electronic ignition and does not use a pilot light.
The igniter may be faulty.or the gas module may be faulty.
Pilots are a thing of the past!
This requires a tech to test it with equipment.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool gas dryer motor wont turn over
If the drum is not turning, then the belt may have broken and could be (because of the noise I think your describing, partially wrapped around the motor pulley.
Modern gas dryers do not have standing pilot lights. They are electronic ignition.
Chances are, you solve the belt problem, you'll solve the (I guess your having) heat problem.
Please respond with more detail of the problems you are having, and advise if the belt is broken.
Jan 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
AEG T57800 Electric Dryer Logo
214 people viewed this question
Top AEG Dryers Experts
John Tripp
John Tripp
DROPNDEAL
DROPNDEAL
Are you an AEG Dryer Expert? Answer questions, earn points and help others
