Question about Taylor 7532 Ultra Thin Glass Digital Scale
Taylor Scale 7532s - not working
My Taylor Scale 7532s was reading "Lo" so I changed out the batteries and now it returns "ERR" then "0 - Ld". Anyone have any ideas?
  • 11 more comments
  • Anonymous Jan 25, 2009
    I have exactly the same problem.... and can't seem to find a fix. Frank
  • Anonymous Apr 18, 2009
    Taylor scale 7532 battery read low replaced the two batteries now the scale shows 20#'s heavier and shows ERR.
    Anyone know how to contact Taylor?
    elee@uwsp.edu
  • ramasamis Apr 24, 2009
    shows 'LO' even after changing battery it does not work
  • Anonymous Apr 26, 2009
    The same problem here. Shows 'Lo' even with new batteries.
  • Anonymous Mar 14, 2014
    manual for taylor 5758 scale
  • Anonymous Mar 15, 2014
    scales takes a 2032 flat battery have replaced the battery & "0.0" shows on display then goes away & stays blank?
    taylor scale shows lo even with new batteries
  • Anonymous Mar 16, 2014
    I turn the scale on and it just continues to blink the 88888. It does not set to zero. I've changed the battery and still have the same problem. I have set something on it to weigh, but it continues to blink 8888.
    Blinks. No zero. No scale. Changed battery.
  • Anonymous Mar 24, 2014
    Scale doesn't work after battery replacement
  • Anonymous Mar 25, 2014
    How to use it model3844-9
  • Anonymous Mar 27, 2014
    changed batteries and now scale does not work
  • Anonymous Mar 28, 2014
    readings continue to flash
  • 74 Answers
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
    Problem Solver:
  • 7 Answers
This link takes you to the troubleshooting section at Taylor :
http://www.taylorusa.com/faq-scales . It explains the error codes and offers suggestions for fixes.
Posted on Dec 09, 2011
I replaced the battery and now the scales read "Err" what do I do now?
hello
I own a cal-max digital scale and i replace batteries and still not working it is showinn err
Feb 27, 2011 | Taylor & Digital Scale Lithium Scale
The taylor lithium electronic scale says 00 and then ERR. there is no ERR2. should i change the batteries? it never said lo.
If you get an "Err" or "Error" message, you will need to step off of the scale, wait a few seconds and then step back onto the scale.
Aug 10, 2010 | Taylor & Digital Scale Lithium Scale
How can I fix the Taylor LIthium Scale?
take it to were you got it or instuctions show u
Feb 09, 2010 | Taylor "TAYLOR" 73304072 LITHIUM BATH...
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
Scales showing Lo after battery has been replaced
Anytime you have trouble with a Taylor scale - they have a lifetime replacement warranty. You need to call their 800 number and pay for 1 way shipping and they will send you a new one.
Jun 04, 2009 | Taylor & Digital Scale Lithium Scale
My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
Mar 16, 2009 | Taylor 7532 Ultra Thin Glass Digital Scale
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
I replaced the batteries in my 7542 scale and it keeps showing err or Lo. What can I do?
have you replaced the batteries with duracell or energizers? I ask this because sometimes when it comes to this type scales using a lower name brand type of battery isnt strong enough for it or there just may be a malfunction in that product. Let me know if this helps and good luck!
Jan 24, 2009 | Taylor & Digital Scale Lithium Scale
Taylor 7532 Ultra Thin Glass Digital Scale Logo
5,330 people viewed this question
Top Taylor Health & Beauty Experts
Norman Worley
Thomas Perkins
Thomas Perkins
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
