Question about Hotpoint 24 in. HDA1000Z Built-in Dishwasher
Water will not drain out of dishwasher
I have a 15 year old Hotpoint dishwasher. It has been making horrible noises for several months now, but it kept working until tonight. Yesterday my DH broke a glass in the dishwasher and tonight (he apparently) broke a long plastic orange peeling stick in half when loading the dishwasher. Now it won't drain the water after the wash cycle. I think that the other half of the orange peeling stick is stuck somewhere in the pump since we can't find it. Also, there may be a piece of glass stuck in the pump as well, if he didn't get it all last night. Where is the pump, and how do we get to it to find out if it is jammed? Thanks so much!
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Trace it back along the outlet pipe and you will find on the pump a unscrewable plug be carefull as you are going to get a few litres of water over the floor
Posted on Apr 08, 2017
SOURCE: Empties and fills but boils the water
hi had the same problem, change the wash pump capacitor, you can get one from maplins
Posted on Jan 19, 2008
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
SOURCE: hotpoint dishwasher bci450
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
Posted on May 23, 2008
  • 6 Answers
SOURCE: DISHWASHER IS LEAKING A LOT OF WATER
Draing Problems:
To fix your draining problem you need to check the air gap(if you have one) , check if there is voltage going to your drain pump during the draining cycle. If there is voltage coming to your water pump and the dishwasher is still not draining then the problem could be a clogged drain hose, a clogged air gap or a bad drain pump. if there is no voltage detedcted on the drain pump during the drain cycle, then it could be a water level-switch/solonioed , wiring, or a control board problem.
Good luck.
Mr Engineer
Posted on Aug 11, 2008
SOURCE: Hotpoint BF1620
What you will find is that the plastic nut fixed on the back panel that the top drawer pushes into has lost the rubber inner layer. Replace and your problem is solved
Kamal
Posted on Mar 12, 2009
Hotpoint Aquarius dishwasher making awful rumble/crackle noise
Have you cleaned the traps and run some vinegar through? They build up dirt from kitchen debris over time which causes the pump and spray rails to pick up sludge. You need to clean them at least every 6 months. Check farther on line for cleaning solutions to clean and maintain dishwashers. I have been hearing clr can be used but can't confirm this.
Oct 23, 2017 | Dishwashers
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
So frustrated - LG dishwasher washes 5 minutes then shows OE code - have cleaned drains, sump pump, out let pipes. Still doing it. ONly 9 months old..... My old dishwasher worked for 10 years.......
Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Nov 08, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Check the drain filter located at the bottom of the wash tub. Clean if clogged. The pump noise could be due to non availability of the washed water continuously due to clog.
Clean the drain filter. Check the final drain output after the pump(hose) for free flow if you have connected it to a drain system.
Aug 03, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Sink dishwater intrusion
Hello- Find drain hose from dishwasher under sink. Should have gooseneck ~ in hose run to keep water from getting back into dwshr. Does full sink drained all at once push water into tub? Sometimes stuff not disposalled yet blocks drainage. Older motors can tend to become weak with age, not pumping as much water out of tub as it used to.Anyway- Hope this helps- ED
Mar 01, 2010 | GE Dishwashers
Our LG LDF7920st dishwasher (6 months old)makes a whistling noise
Hey, consider the float assembly!
We bought this dishwasher and ran it for the last 1 1/2 months and it made a grinding and whistling sound from day one (it's supposed to be nearly silent in its operation). Turns out the drain pump was cutting in while the machine was still filling, thereby emptying the wash tub of any water. Then, when the cycle proceeded to wash, the dumb thing had no water and made a horrible noise. So I had to pitch in at least 2-3 litres of hot water, and then it worked quietly! Had to do this every time there was new water intake.
After working with the repairmen - four visits later, we isolated the float assembly as the problem and they set about replacing the part. Turns out the two parts were markedly different. LG HAD INSTALLED an older model float assembly at the factory and it was the problem. The replacement part was the correct float assembly and things worked perfectly after that - thank goodness. No more babysitting the dishwasher.
Don't let anyone tell you the motor assembly needs replacement. I have seen that cop-out 'fix' all over the web. But use deductive reasoning to find out where the problem is in the cycle, and explore this option first - it's a quicker and cheaper fix than replacing the whole motor assembly.
'Mr. Float' as he is now called works like this:
-expels any residual water in the tub from the last wash
-intakes water for the wash or rinse
-whirs 2-3 times prepping for the cycle
-begins to wash, quietly
-expels at the end of the wash or rinse.
He used to:
-expel residual water
-intake new water for wash or rinse
---drain pump would cut in WHILE still filling
-machine would whir once, realize it didn't have enough water
-perform a brief top-up intake shot
-begin to wash and whistle and GRIND (this is where I would have to add the water)
-expels water from wash or rinse, and start all over again.
It's a good dishwasher and it will work, but the right model parts have to be in place!
Jun 27, 2009 | LG Dishwashers
Dwf 33
Took sides off to have a look.
Then turned on (but didn't touch!!) and was still making noise but no water. Lifted the float switch up and down and the water then started to come into machine. Drained machine and started it up again a few times to check wasn't a fluke and all seems well again!!! I was virtually on the point of giving in and buying new one as its 8 years old but hurray! not going to be that broke this month!! Husband will be pleased.
Sep 04, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Smells bad
I have a very bad smell in my elite kenmore diswasher. We have had it for a year now. I have been smelling this now for several weeks and I didn't know where the smell was coming from until this morning when I pulled the door down to unload my dishes.
Jul 14, 2008 | Hotpoint 24 in. HDA3700G Built-in...
Hotpoint 24 in. HDA1000Z Built-in Dishwasher Logo
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
